Unity 8 - Message store wizard failure
I am setting up unity failover (8.0.3) and the install fails @ message store wizard.
It asks for the install and administration account and fails right after i pick the administration account. I am positive that the entered credentials are correct.
Its failing with the error, "Message Store Configuration encountered errors. Return Code -1073741811.
Few hours back, i was able to set-up unity primary with no issues (which is functioning right now).
Anyone know where the install logs will be? And insight please, where to look next?
I hate to rebuild from scratch again
Senthil
Bradford Magnani
Bradford Magnani
Senthil,
I wrote the defect for this, its a known issue:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCth77070
Hope that helps,
Brad
You are correct. Thanks Brad.
