Media Resource - Registration Reject
Jul 28th, 2010
Hi guys,
I have an implementation of CallManager (version 6.1.2) and gateway 3845 (IOS 12.4.24T2).
I have configured conferencing, transcoding and MTP-RSVP resources in the gateway (config attached).
When I set the "sccp ccm <IP CM> identifier 1" without the option "version" (default 3.1), transcoding and conference resources registering ok, but not MTP-RSVP.
When I set the "sccp ccm <IP CM> identifier 1" with the option "version" = 6, transcoding and conference resources not registering (Media Resource configuration in CallManager as Cisco IOS or Cisco IOS Advanced), but MTP-RSVP working ok.
Suggestions?
Ronaldo Gama
Adam Frankel Wed, 07/28/2010 - 14:24
  • Silver, 250 points or more
I would suggest starting with version 6 if your CUCM is version 6 and troubleshooting why the CFB and Transcoder will not register.  Most likely you are specifying the incorrect device type in CUCM.
HTH,
-Adam
