VIC3 4FXS DID and Valcom Paging system
Jul 28th, 2010
Hey Community,
I am trying to connect a Valcom paging system to a 2821 router using a VIC3-4FXS/DID card. It is currently configured on a VIC2-4FXO card and works fine. But I need to free the fxo card for other uses. I attempted to configure it on the FXS the same way it was on the FXO. No bueno! I could see the 2821 receiving the call on the port, but still unable to make the page. It just rings and rings. Is this possible or am i just shooting blanks?
Sincerely,
A new fish in the voip pond!
Overall Rating: 5 (1 ratings)
Tracy Larson Fri, 07/30/2010 - 08:12
  • Silver, 250 points or more
I think the v9970 might be what he needs to tie into an fxs port.
Steven Holl Fri, 07/30/2010 - 08:15
  • Cisco Employee,
Yeah, if the device is working on an FXO currently, then that means you'll never get it to work on an FXS port.  FXS always connects to FXO on the other side.
So you currently have it working, you essentially have this:
Gateway(FXO)------(FXS)Valcom
You are trying to do this:
Gateway(FXS)-----(FXS)Valcom
FXS to FXS won't ever work.  If you want to use an FXO on the gateway, you'd need a device in the middle had an FXO on both sides and did this:
Gateway(FXS)----(FXO)Adapter(FXO)---Valcom
I don't know if they make a device that does that.
Only other option is to get a Valcom system that has an FXO port instead of an FXS port, which will likely require new hardware or a new device.  Valcom support can probably speak more on behalf of that.
