AP 1130 question about All radios disabled -LOW_POWER_CLASSIC_NO_INJECTOR_CONFIGURED WS-C2950G-48-EI
Answered Question
Jul 28th, 2010
Hi everyone:
    In my WLC, I found a trouble about one of my 1130AP. the issue follows" LOW_POWER_CLASSIC_NO_INJECTOR_CONFIGURED WS-C2950-48-EI". so I checked the doucment about this issue. however, the doucment gives me the description of issue " CDP_PD-2-POWER_LOW: All radios disabled-LOW_POWER_CLASSIC_NO_INJECTOR_CONFIGURED" on Access point. As that troubleshooting step I did, but it is useless.
    Further to the response from doucment. Is it imperative that I disable CDP on the switch? if it is not, how to solve it.
Correct Answer by Leo Laohoo about 6 years 5 months ago
Go to Wireless > All APs > AP of your choice > Advanced tab
Under "Power Over Ethernet Settings" put a tick on Power Injector State and enter the MAC address of the port of the 2950 switch and click Apply.
Please don't forget to rate useful posts.  Thanks.
Overall Rating: 5 (1 ratings)
Correct Answer
Leo Laohoo Wed, 07/28/2010 - 21:02
sisivciii Wed, 07/28/2010 - 21:32
Hi Leo
    I will try it. I won't forget to give u a rate useful posts. LOL
sisivciii Tue, 08/03/2010 - 02:50
Hi Leo
    Maybe your environment is built on WLC. but I am using a AP and not a L-AP. so i did not find any option which you mention me in AP operation web.
but your thinking is right.
   I typed the command: power inline negotiation injection MAC" MAC means the port of the switch that connects AP.
   I just want to know why I have to type this command, I have never ever typed this command. and I did not find any feature about this command. and CIsco's document doest not mention.
  Thanks you again
