Cisco PIX 501 with transparent mode Configuration Example
Jul 28th, 2010
edadios Thu, 07/29/2010 - 00:23
I refer you to the following command reference on 7.0
command for enabling transparent mode is since version 7.0
pix 501 does not support 7.x and later code
In short, firewall mode transparent is not supported on pix 501.
Sorry that it does not help your cause, but hopefully clarifies the pix501 capability.
Maybe you should instead make the modem transparent, or if possible make the pix a pppoe client to your provider
