6901 IP phone
Jul 29th, 2010
I have CUCM 7.1.3 in the network. I am trying to install new Cisco IP phone 6901, but not getting option for this model of phone in CUCM.
Please suggest if I need to install firmware or patch on CUCM.
It will be great if it can be known whether this model support Extension mobility or not ?
Abhas Jain
Aaron Harrison Thu, 07/29/2010 - 04:58
According to the release notes it is supported first in 7.1.3.
I would download and install the latest Device Package as this would normally add support for new phones... it will also update existing phone firmware...
Generally no screen = no Extension Mobility; I don't see support for that feature on the release notes.
Aaron
alijames Thu, 07/29/2010 - 06:15
Yes, you need the latest Device Package (7.1(3.33031), which will require a reboot of UC servers. I applied this last week on our production after a weeks testing on our dev cluster, with no problems.
Cheers,
Alistair
Matthew Kaufman Thu, 07/29/2010 - 07:24
Update to either the latest 7.1.3 device pack or to the latest 7.1.5 SU would include this device type.
Data sheet for this phone is below:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps10326/data_sheet_c78-584412.html
Since this is an very basic entry-level IP Phone, it will not include many of the features available in 79XX, 89XX or 99XX series phones.
Related Content
