Temperature 6509 VSS
Answered Question
Jul 29th, 2010
  • Silver, 250 points or more
Dear all,
I have not really experiens with the temperature with the 6509.
I chech the enviroment and got the followin output. Is it normal or should I be alarmed?
I know the operation temp. 0-40°, but I'm afraid of the asic temp.
Thanks in advande!
Best regards
Sebastain
#sh  environment switch 1 temperature
chassis id 1 switch_id 1
  switch 1 VTT 1 outlet temperature: 28C
  switch 1 VTT 2 outlet temperature: 27C
  switch 1 VTT 3 outlet temperature: 25C
  switch 1 module 1 outlet temperature: 36C
  switch 1 module 1 inlet temperature: 23C
  switch 1 module 1 EARL outlet temperature: 30C
  switch 1 module 1 EARL inlet temperature: 26C
  switch 1 module 2 outlet temperature: 35C
  switch 1 module 2 inlet temperature: 23C
  switch 1 module 2 EARL outlet temperature: 27C
  switch 1 module 2 EARL inlet temperature: 24C
  switch 1 module 3 outlet temperature: 33C
  switch 1 module 3 inlet temperature: 22C
  switch 1 module 3 EARL outlet temperature: 26C
  switch 1 module 3 EARL inlet temperature: 24C
  switch 1 module 4 outlet temperature: N/A
  switch 1 module 4 inlet temperature: N/A
  switch 1 module 4 EARL outlet temperature: N/A
  switch 1 module 4 EARL inlet temperature: N/A
  switch 1 module 6 outlet temperature: 32C
  switch 1 module 6 inlet temperature: 21C
  switch 1 module 6 device-1 temperature: 25C
  switch 1 module 6 device-2 temperature: 28C
  switch 1 module 6 asic-1 temperature: 51C
  switch 1 module 6 asic-3 temperature: 34C
  switch 1 module 6 asic-4 temperature: 53C
  switch 1 module 6 RP outlet temperature: 25C
  switch 1 module 6 RP inlet temperature: 25C
  switch 1 module 6 EARL outlet temperature: 26C
  switch 1 module 6 EARL inlet temperature: 20C
  switch 1 module 8 outlet temperature: 36C
  switch 1 module 8 inlet temperature: 24C
  switch 1 module 8 aux-1 temperature: 34C
  switch 1 module 8 aux-2 temperature: 26C
  switch 1 module 8 asic-1 temperature: 61C
  switch 1 module 8 asic-2 temperature: 61C
  switch 1 module 8 EARL outlet temperature: 26C
  switch 1 module 8 EARL inlet temperature: 23C
Correct Answer by Jayakrishna Mada about 6 years 11 months ago
Hi ,
Check the output of "show environment alarm thresholds switch 1 module x" command and you will see the minor and major alarm thersholds. if the value that you are seeing is with in that range you should be good.
JayaKrishna
Overall Rating: 5 (1 ratings)
Correct Answer
Jayakrishna Mada Thu, 07/29/2010 - 21:26
  • Cisco Employee,
Hi ,
JayaKrishna
Sebastian Helmer Thu, 07/29/2010 - 23:07
In my case I needed the command "sh environment switch 2 alarm thresholds". But your reply helps me much.
Thanks a lot.
best,
sebastian
Hello. We have VSS cluster of two Cisco 6509 with Supervisor Engine 720 10GE.
Some time ago we began to receive env traps about exceed ASIC temperature on one SUP module from Cisco LMS:
EVENT DESCRIPTION = OutOfRange::Component=TEMP-SPB_M69-SW01F0-C/1011 [Chassis 2 module 5 asic-4 temperature Sensor-Chassis 2 module 5 asic-4 temperature Sensor];ComponentClass=TemperatureSensor;ComponentEventCode=1079;Status=OK;entSensorValue=46;CurrentValue=46.0  DEGC;
#show environment switch 2 alarm thresholds module 5
chassis id 2 switch_id 2
switch 2 module 5 power-output-fail: OK
  threshold #1 for switch 2 module 5 power-output-fail:
    (sensor value != 0 ) is system minor alarm
switch 2 module 5 insufficient cooling: N/A
  threshold #1 for switch 2 module 5 insufficient cooling:
    (sensor value != 0 ) is system major alarm
switch 2 module 5 fan-upgrade required: N/A
  threshold #1 for switch 2 module 5 fan-upgrade required:
switch 2 module 5 outlet temperature: 26C
  threshold #1 for switch 2 module 5 outlet temperature:
    (sensor value >= 70C) is system minor alarm
  threshold #2 for switch 2 module 5 outlet temperature:
    (sensor value >= 85C) is system major alarm
switch 2 module 5 inlet temperature: 15C
  threshold #1 for switch 2 module 5 inlet temperature:
    (sensor value >= 65C) is system minor alarm
  threshold #2 for switch 2 module 5 inlet temperature:
    (sensor value >= 80C) is system major alarm
switch 2 module 5 asic-1 temperature: 44C
  threshold #1 for switch 2 module 5 asic-1 temperature:
    (sensor value >= 90C) is system minor alarm
  threshold #2 for switch 2 module 5 asic-1 temperature:
    (sensor value >= 105C) is system major alarm
switch 2 module 5 asic-3 temperature: 28C
  threshold #1 for switch 2 module 5 asic-3 temperature:
    (sensor value >= 95C) is system minor alarm
  threshold #2 for switch 2 module 5 asic-3 temperature:
    (sensor value >= 110C) is system major alarm
switch 2 module 5 asic-4 temperature: 44C
  threshold #1 for switch 2 module 5 asic-4 temperature:
  threshold #2 for switch 2 module 5 asic-4 temperature:
How can i increase threshold of temperature alarm or filter this alarm on Cisco LMS?
Earlier, i heard that these threshold settings for envmon cannot be changed, so how can i fix this?
There are up to 1000 such alerts comes every day.
Thanks in advance.
swamyrc_11 Sat, 10/22/2011 - 03:26
Thanks for the replay, below is the output please let us know what action to be taken.
SWZ-CORE-A#show environment alarm thresholds switch 1 module 5
switch 1 module 5 power-output-fail: OK
threshold #1 for switch 1 module 5 power-output-fail:
(sensor value != FALSE ) is system minor alarm
switch 1 module 5 insufficient cooling: N/A
threshold #1 for switch 1 module 5 insufficient cooling:
(sensor value != FALSE ) is system major alarm
switch 1 module 5 fan-upgrade required: N/A
threshold #1 for switch 1 module 5 fan-upgrade required:
switch 1 module 5 outlet temperature: 31C
threshold #1 for switch 1 module 5 outlet temperature:
threshold #2 for switch 1 module 5 outlet temperature:
switch 1 module 5 inlet temperature: 19C
threshold #1 for switch 1 module 5 inlet temperature:
threshold #2 for switch 1 module 5 inlet temperature:
switch 1 module 5 asic-1 temperature: 49C
threshold #1 for switch 1 module 5 asic-1 temperature:
threshold #2 for switch 1 module 5 asic-1 temperature:
switch 1 module 5 asic-3 temperature: 34C
threshold #1 for switch 1 module 5 asic-3 temperature:
threshold #2 for switch 1 module 5 asic-3 temperature:
switch 1 module 5 asic-4 temperature: 44C
threshold #1 for switch 1 module 5 asic-4 temperature:
threshold #2 for switch 1 module 5 asic-4 temperature:
Thanks and Regards
