How to activate ephone-dn changes in SRST/CME
Jul 29th, 2010
Hi All,
I’m using SRST fallback mode using Cisco Unified Communications Manager Express (Cisco Unified CME) and its working ok.
Under telephony-service I configured a ephone-dn-template so some settings are pushed to the phones in SRST.
I’d like to disable the call-waiting-beep on the phones, so I changed ephone-dn-template 1 and added the option ‘no call-waiting beep accept’. See configuration below
srst mode auto-provision none
srst ephone template 1
srst dn template 1
srst dn line-mode dual
I switched between the normal mode and SRST mode, but the ‘call-waiting beep’ is still activated. Eventually the call-waiting beep was disabled after rebooting the router.
- Is there a more elegant way the activate these changes on the phones?
- Is there a way to remove a dynamically discovered ephone in SRST/CME?
Aaron Harrison Thu, 07/29/2010 - 04:13
You could try issuing the reset command under telephony-service config mode to reset the phones...
theo.wiersma Thu, 07/29/2010 - 05:33
/* Style Definitions */ table.MsoNormalTable {mso-style-name:Standaardtabel; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Hi Aaron,
I already tried this…. No luck..
