Reg. NAT Query in ASA
Answered Question
Jul 29th, 2010
hi halijenn / experts,
I want to configure NAT for the Network 192.168.16.0/24 to destination 192.168.41.2/32 which must be translated to  2.2.2.2.Also few of the servers
addresses on 192.168.16.0/24 must be translated to different NAT addresses to all other destination (except 192.168.41.2).For example,
192.168.16.2 must be translated to 2.2.2.4 while going to any destination (except 192.168.41.2)
Please let me know if the below is correct
access-list ACLPOLICY extended permit ip 192.168.16.0 255.255.255.0 host 192.168.41.2
nat (INSIDE) 1 access-list ACLPOLICY
nat (INSIDE) 2 192.168.16.2 255.255.255.255
global (OUTSIDE) 1 2.2.2.2
global (OUTSIDE) 2 2.2.2.4
The issue is that according to NAT Order of operations NAT 0 with ACL comes first , followed by existing xlates and so on .Hence when the user will
initiate the connection from 192.168.16.2 to www.google.com , the translation entry will be created for the 192.168.16.2 with the global 2.2.2.4 ; however
if at the same time the user will try to access destination 192.168.41.2 , will the firewall take the existing translation or it will consider 2.2.2.2 for NATTING
In my case the packet doesnot consider the existing xlates and doesnot takes the correct NAT.Plz let me know if any other solution exists to accomplish
the same.
Correct Answer by Jennifer Halim about 6 years 11 months ago
You should have 2 lines of xlate entries, one for each global address it's PATed to.
You can check more details from "show xlate detail" output.
Actually, just thinking further on NAT, if you are going to a different destination, that will not be considered as the same translation/existing translation. A translation line will only be from the same source towards the same destination with multiple connections (eg: http, https, ftp, etc) on 1 translation line.
Hence, from your example, if it's not going towards destination of 192.168.41.2 then it will check the next NAT statement inline, and should match your "nat (inside) 2 192.168.16.2"
NT is correct, configuration is OK for what you are trying to achive as long as it is exactly how it is configured in your firewall (ie: the order of the NAT statements on the actual firewall).
Correct Answer by Nagaraja Thanthry about 6 years 11 months ago
Your configuration looks good. When the traffic hits the firewall, the NAT with the ACL is evaluated before other NAT rules. So, in your case, if the traffic is going to 192.168.42.x, then the first NAT rule will be applied. Also, the other thing to notice is that, while the firewall looks into the XLATE table to see if there is any current XLATE, it is bound by the access-list rules. So, with the configuration you have, you should be able to acheive the goal.
Hope this helps.
NT
Overall Rating: 5 (3 ratings)
Jennifer Halim Thu, 07/29/2010 - 04:17
  • Cisco Employee,
hi Ankur,
You are right. NAT 0 with ACL takes precedence over all other NAT statements, hence, NAT 0 with ACL is normally configured very specific on the ACL. If the ACL does not match the NAT 0 statement, then it will check for static NAT, then the normal identity NAT statements.
In your scenario, if there is an existing translation for 192.168.16.2 to 2.2.2.4, then every other connections will be using 2.2.2.4 until you actually do a "clear xlate" for that particular host 192.168.16.2. Once you clear the translation for that host, if the host is trying to access 192.168.41.2 host, it will be PATed to 2.2.2.2.
Bear in mind that the NAT statements configured on your firewall is exactly in the other as your sample configuration posted. With identity NAT, it process the list from top to bottom, so if it matches specific NAT statement on the top, then it will stop going through the list. It does not try to match a more specific NAT statement.
Hope that helps.
ankurs2008 Thu, 07/29/2010 - 05:05
Hi halijenn
Thanks for the reply !
Is there any alternative solution for my query and that too without doing "clear xlate " everytime.
Also as according to your below statement " With identity NAT, it process the list from top to bottom, so if it matches specific NAT statement on the top, then it will stop going through the list. It does not try to match a more specific NAT statement"  , does this mean that the above is not possible even with the identity NAT ?
Correct Answer
Jennifer Halim Thu, 07/29/2010 - 05:23
  • Cisco Employee,
Correct Answer
Nagaraja Thanthry Thu, 07/29/2010 - 05:19
  • Cisco Employee,
Hope this helps.
NT
ankurs2008 Thu, 07/29/2010 - 05:53
Hi halijenn / NT
Thanks a ton !
Halijenn , please explain me a little more on below statement
Jennifer Halim Thu, 07/29/2010 - 06:58
  • Cisco Employee,
What I mean is 1 xlate entry (translation entry) might consists of multiple connections if the source and destination is the same.
You can also configure policy NAT for specific application, eg: if a source is going to a specific destination on telnet port, PAT it to 1.1.1.1, and if the same source is going to the same destination on http port, PAT it to 1.1.1.2. So basically, you can configure the policy NAT with just source and destination in the ACL, or more granular policy with destination port as well.
Here is the document for your reference:
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/nat_overview.html#wp1088419
Hope that makes sense.
ankurs2008 Mon, 08/02/2010 - 03:37
Hi halijenn
thanks for the reply . I understood it ; however i have a query regarding the output of "sh xlate " in the firewall . Will i be able to see only one "local" to global " mapping for 192.168.16.2 as per the below scenario ? ie what will be the output of "sh xlate " when i try to access internet and IP 192.168.41.2 both at the same time with the source IP 192.168.16.2 .
Correct Answer
Jennifer Halim Mon, 08/02/2010 - 08:52
  • Cisco Employee,
ankurs2008 Tue, 08/03/2010 - 02:26
hi halijenn
thanks a lot ! i believe we can see the same via "show nat " command as well .
