ACS 4.2, Wireless Authentication PEAP/EAP-TLS & Certificates
Hi All,
I have a requirement on our wireless network to ONLY approve authentication from machines that are pre-approved. We have our wireless network setup and it's all working well using RADIUS to Microsoft AD servers on the ACS for end user/machine authentication.
We've recently installed a new digital certificate and have enabled EAP-TLS for machine authentication - again all is working as expected with the certificate being downloaded/provided to the remote client as when connection occurs.
Waht I want to do now is actually STOP the provision of the certificate so that I have to use a microsoft Group Policy to install onto the remote clients. In this way I'm thinking that I can then ONLY approve clients that have the correct certificate installed.
Sounds simple, but can I find a way of doing it? - no ... (is what I'm trying to do even possible?)
Any assiatance greatly received ...
AdmSeguridad01 Wed, 08/25/2010 - 14:28
I'm having exactly the same problem, but backwards. I want to install automatically the certificate in my wireless clients. I'm running ACS 4.2 also and I have been running tests, but I have to install manually the generated certificate in each wireless client (300 laptops).
So I would like to know which configuration are you using (in case it's possible you could send me the running config that you have actually installed).
Thank you very much.
