More than 1 wifi user kills connection
Jul 29th, 2010
I have a new 1300 series outdoor AP.  Using wpa2/aes-ccm and local radius/eap-fast.
The first user connects/auths fine and can browse relatively fast.  When the second user connects, both connections are unusable.  Ping responses are in the 15000 ms range (if there is any icmp response at all)
What could be causing this?
XXX#show dot11 associations al
Address           : 001b.777c.a97b     Name             : NONE
IP Address        : xxx.xxx.xxx.xxx     Interface        : Dot11Radio 0
Device            : unknown            Software Version : NONE
CCX Version       : 4                  Client MFP       : Off
State             : EAP-Assoc          Parent           : self
SSID              : XXX_Public
VLAN              : 0
Hops to Infra     : 1                  Association Id   : 1
Clients Associated: 0                  Repeaters associated: 0
Tunnel Address    : 0.0.0.0
Key Mgmt type     : WPAv2-CP           Encryption       : AES-CCMP
Current Rate      : 54.0               Capability       : WMM ShortHdr ShortSlot
Supported Rates   : 1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
Voice Rates       : disabled           Bandwidth        : 20 MHz
Signal Strength   : -62  dBm           Connected for    : 49 seconds
Signal to Noise   : 20  dB            Activity Timeout : 1798 seconds
Power-save        : Off                Last Activity    : 2 seconds ago
Apsd DE AC(s)     : NONE
Packets Input     : 172                Packets Output   : 129
Bytes Input       : 39687              Bytes Output     : 24551
Duplicates Rcvd   : 0                  Data Retries     : 46
Decrypt Failed    : 0                  RTS Retries      : 1
MIC Failed        : 0                  MIC Missing      : 0
Packets Redirected: 0                  Redirect Filtered: 0
PMKIDs:
       FD6FAF4F4D710A19232BC670D703E0D0
Session timeout   : 0 seconds
Reauthenticate in : never
Address           : 0026.ff1e.6574     Name             : NONE
SSID              : XXX_Public
VLAN              : 0
Hops to Infra     : 1                  Association Id   : 2
Key Mgmt type     : WPAv2              Encryption       : AES-CCMP
Signal Strength   : -68  dBm           Connected for    : 54 seconds
Signal to Noise   : 13  dB            Activity Timeout : 1800 seconds
Power-save        : On                 Last Activity    : 0 seconds ago
Apsd DE AC(s)     : BK BE VI VO
Packets Input     : 366                Packets Output   : 60
Bytes Input       : 18999              Bytes Output     : 18794
Duplicates Rcvd   : 3                  Data Retries     : 20
Decrypt Failed    : 0                  RTS Retries      : 40
Surendra BG Wed, 08/18/2010 - 09:07
  • Cisco Employee,
To which switch are we connecting the Bridges to?? is that the Linksys switch or any small office home office switches?
regards
surendra
