07-29-2010 04:40 AM - edited 03-11-2019 11:17 AM
HI
I an using ASA 5505 in my network. I have two ISP . I want to configure Daul ISP. So that when Primary goes down, Backup ISP can handle down time.
But after whole Configration , when I put my primary ISP Down, Backup ISP external IP start pinging outside and i wont be able to run internet in internel netowork.
Can some one help.
Amardeep Rana
07-29-2010 04:45 AM
Have you configured tracking for the ISP failover? If i understand your problem right, you have no internet access from internal once primary goes down right? What is the nat configuration u have?
07-29-2010 04:57 AM
HI Rahgovin,
You are right , I have no access on internet internally. here is waht I did
ASA5505(config)# interface ethernet 0/0
ASA5505(config-if)# switchport access vlan 2
ASA5505(config-if)# no shutdown
ASA5505(config)# interface ethernet 0/1
ASA5505(config-if)# switchport access vlan 1
ASA5505(config)# interface ethernet 0/2
ASA5505(config-if)# switchport access vlan 3
ASA5505(config)# interface vlan 1
ASA5505(config-if)# nameif inside
ASA5505(config-if)# security-level 100
ASA5505(config-if)# ip address 192.168.1.1 255.255.255.0
ASA5505(config)# interface vlan 2
ASA5505(config-if)# nameif primary-isp
ASA5505(config-if)# security-level 0
ASA5505(config-if)# ip address Primary ISP Exteral IP 255.255.255.0
ASA5505(config-if)# backup interface vlan 3
ASA5505(config)# interface vlan 3
ASA5505(config-if)# nameif backup-isp
ASA5505(config-if)# ip address Backup Isp 2 255.255.255.0
ASA5505(config)# route primary-isp 0.0.0.0 0.0.0.0 Primary ISP Exteral IP 1
ASA5505(config)# route backup-isp 0.0.0.0 0.0.0.0 Backup Isp 2
Check also
nat (inside) 1 192.168.1.0 255.255.255.0
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx 1 track 1
route outside 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx 2
Amardeep Rana
07-29-2010 05:11 AM
So when u failover are u able to ping 4.2.2.2 from the firewall itself?
And do u have global commands for both primary and backup interfaces?
If both the answers are yes, try a packet tracer for an icmp packet from inside host to 4.2.2.2 and see where it fails when u are on your backup isp.
07-30-2010 01:39 AM
HI Rahgovin,
Thanks I am able to run internet , I have to make setting as my configratuion and I am up after that. Thank You for your hints this worked for me......
Thank You everyone.
Amardeep Rana
07-29-2010 05:14 AM
can you please paste the entire config of the nat commands, looks like a nat issue
if its not an issue please post the entire config by making the public ip's
else plz paste the following
show run nat
show run global
show run static
configuration part of sla monitoring (you can pull out lines from your config)
you can refer to this doc for configuration in case you have doubt whether you have configured it properly
07-29-2010 01:49 PM
HI
Here is details of commnds.
ciscoasa(config)# show run nat
nat (inside) 0 access-list 101
nat (inside) 1 192.168.12.0 255.255.255.0
ciscoasa(config)# show run globa
ciscoasa(config)# show run global
global (outside) 1 interface
ciscoasa(config)# sh run stati
ciscoasa(config)# sh run static
static (inside,outside) xxx.xxx.xxx.xxx.168.12.56 netmask 255.255.255.255
static (inside,outside) xxx.xxx.xxx.xxx 192.168.12.77 netmask 255.255.255.255
static (inside,outside) xxx.xxx.xxx.xxx 192.168.12.38 netmask 255.255.255.255
static (inside,outside) xxx.xxx.xxx.xxx 192.168.12.28 netmask 255.255.255.255
static (inside,outside) xxx.xxx.xxx.xxx 192.168.12.30 netmask 255.255.255.255
static (inside,outside) xxx.xxx.xxx.xxx 192.168.12.19 netmask 255.255.255.255
static (inside,outside) xxx.xxx.xxx.xxx mailserver netmask 255.255.255.255
static (inside,outside) xxx.xxx.xxx.xxx 192.168.12.62 netmask 255.255.255.255
static (inside,outside) xxx.xxx.xxx.xxx 192.168.12.65 netmask 255.255.255.255
static (inside,outside) xxx.xxx.xxx.xxx 192.168.12.59 netmask 255.255.255.255
static (inside,outside) xxx.xxx.xxx.xxx 92.168.12.100 netmask 255.255.255.255
static (inside,outside) xxx.xxx.xxx.xxx 192.168.12.41 netmask 255.255.255.255
static (inside,outside) xxx.xxx.xxx.xxx 192.168.12.49 netmask 255.255.255.255
ciscoasa(config)#
thanks
Amardeep Rana
