Natting
Jul 29th, 2010
    HI
I want to configure two natting statment with my sinlge local IP for my mail Server. Is it possible to create another router with same local ip for another extenal IP. I am using ASA 5505.
Right now I have
static (inside,outside) xxx.xxx.xxx.xxx 192.168.12.49 netmask 255.255.255.255
static (inside,outside) yyy.yyy.yyy.yyy  192.168.12.49 netmask 255.255.255.255  ( I want to do like this)
Amardeep Rana
Rahul Govindan Thu, 07/29/2010 - 05:01
  • Silver, 250 points or more
No. I think it will complain about duplicate entries to the first static when u try to enter the second static command.
Jitendriya Athavale Thu, 07/29/2010 - 05:18
  • Cisco Employee,
this will not be possible you can map ports if you have specific example
for example
static (inside,outside) tcp xxx.xxx.xxx.xxx 25 192.168.12.49 25 netmask 255.255.255.255
static (inside,outside) tcp yyy.yyy.yyy.yyy  22 192.168.12.49 22 netmask 255.255.255.255
but just curious, wouldnt your server complain of ip conflict in your internal network as 2 devices have the same ip
Amardeep Kumar Thu, 07/29/2010 - 05:25
HI
I have only one server with local ip of 192.168.12.49. But I want to create two nat route with this and I get the error of
duplicity..
Amardeep Rana
Amardeep Kumar Thu, 07/29/2010 - 05:26
HI
Yes , You are right , this is giving me same error og duplcity.
So you mean , I am not able to map single local IP to my another two external IP.
Any Idea , I can do it..
Amardeep Rana
Jitendriya Athavale Thu, 07/29/2010 - 05:30
  • Cisco Employee,
as i said the only option is static pat wherein you can map specific ports
the reason is simple when the server is sending a packet out it will not know which public ip to use
can you elaborate more on what service this host is running
whether the 2 ip's need to be translated on the same interface
why exactly do you need to translate it to 2 ip's unless the server is running 2 services
Amardeep Kumar Thu, 07/29/2010 - 05:38
HI
This is my mail server.And I want to put it up everytime. Some time what happens my primary ISP goes down so I have to roll over on Backup iSP. So I want to map the same server on two ISP external IP. So that server can be up everytime.
Amardeep Rana
Nagaraja Thanthry Thu, 07/29/2010 - 05:47
  • Cisco Employee,
Are both your ISP's connected to same outside interface? If yes, my earlier
post has the configuration example that will achieve what you are looking
for. If they are on different interface of the firewall, then you need not
have to worry about duplicate entries and just configure normal static NAT.
static (inside,ISP1) xxx.xxx.xxx.xxx 192.168.12.49 netmask 255.255.255.255
static (inside,ISP2) yyy.yyy.yyy.yyy 192.168.12.49 netmask 255.255.255.255
The firewall will choose the static based on the outgoing interface.
Hope this helps.
NT
Amardeep Kumar Fri, 07/30/2010 - 01:32
HI Nagaraja Thanthry,,
I think your answer worked for me and I was able to make two route. But As I created second route, My internet stop working.
static (inside,ISP2) yyy.yyy.yyy.yyy 192.168.12.49 netmask 255.255.255.255 , As I put this command, My first entry stop working, Internet was not working on the same server which IP I am using for two routes. To resolve the issue I have to remove both of the entry from ASA and map another IP to my mail server and after it start running. 192.168.12.49 server stop
running after my sesond static command.
I tried clear xlate but in vain.
Please suggest
Nagaraja Thanthry Thu, 07/29/2010 - 05:41
  • Cisco Employee,
You can use policy-nat.
access-list PNAT1 permit ip host 192.168.12.49 any
access-list PNAT2 permit ip host 192.168.12.49 any
static (inside,outside) xxx.xxx.xxx.xxx access-list PNAT1
static (inside,outside) yyy.yyy.yyy.yyy access-list PNAT2
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807d2874.shtml
Hope this helps.
NT
Amardeep Kumar Thu, 07/29/2010 - 05:52
HI
Let me try with this configration. I will update it soon.
Amardeep Rana
Amardeep Kumar Fri, 07/30/2010 - 07:07
HI
I have a A records on Godaddy for my some of the servers. I have created natting lcoal IP to external IP and I access those servers via Name. What I have made some change on ASA 5505 after that none of the IP was pinging outside. I have to change all of my static routes to different IPs. after they are runnging. Is there any issue second ISP router can create. What is roll of Xlate . Please suggest , I dont have much IP in my Pool. Please help
Amardeep K
Nagaraja Thanthry Fri, 07/30/2010 - 07:14
  • Cisco Employee,
Can you please post the output of "show run interface", "show run static", and "show run route" here? You can sanitize your IP addresses if you like.
NT
Amardeep Kumar Fri, 07/30/2010 - 07:23
HI
Output of these three Commands
ciscoasa(config)# sh run interface
interface Vlan1
nameif inside
security-level 100
ip address Local IP 255.255.254.0
interface Vlan2
nameif outside
security-level 0
ip address Extrenal 255.255.255.224
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
switchport access vlan 3
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
switchport access vlan 22
sh run static
static (inside,outside) xxx.xxx.xxx.xxx 192.168.12.62 netmask 255.255.255.255
static (inside,outside) xxx.xxx.xxx.xxx 192.168.12.59 netmask 255.255.255.255
static (inside,outside) xxx.xxx.xxx.xxx 192.168.12.100 netmask 255.255.255.255
static (inside,outside) xxx.xxx.xxx.xxx 192.168.12.41 netmask 255.255.255.255
static (inside,outside) xxx.xxx.xxx.xxx exchange01 netmask 255.255.255.255
static (inside,outside) xxx.xxx.xxx.xxx 192.168.12.65 netmask 255.255.255.255
static (inside,outside) xxx.xxx.xxx.xxx 192.168.12.19 netmask 255.255.255.255
( I have to recreate all static again , AS I was not able to access them after Daul ISP setup Or after putting this command
static (inside,ISP2) yyy.yyy.yyy.yyy 192.168.12.49 netmask 255.255.255.255.
show run route
route outside 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx 1 track 1
Amardeep Rana
Nagaraja Thanthry Fri, 07/30/2010 - 07:32
  • Cisco Employee,
Did you have another interface (Vlan 22) named ISP2? Did you by any chance
used "backup-interface" configuration on the firewall? Can you please post
the configuration with the second ISP interface here?
NT
Amardeep Kumar Fri, 07/30/2010 - 07:44
Hi ,
I have used this config but As I got issue I rebooted my ASA .
ASA5505(config)# interface ethernet 0/0
ASA5505(config-if)# switchport access vlan 2
ASA5505(config-if)# no shutdown
ASA5505(config)# interface ethernet 0/1
ASA5505(config-if)# switchport access vlan 1
ASA5505(config)# interface ethernet 0/2
ASA5505(config-if)# switchport access vlan 3
ASA5505(config)# interface vlan 1
ASA5505(config-if)# nameif inside
ASA5505(config-if)# security-level 100
ASA5505(config-if)# ip address 192.168.1.1 255.255.255.0
ASA5505(config)# interface vlan 2
ASA5505(config-if)# nameif primary-isp
ASA5505(config-if)# security-level 0
ASA5505(config-if)# ip address Primary ISP Exteral IP 255.255.255.0
ASA5505(config-if)# backup interface vlan 3
ASA5505(config)# interface vlan 3
ASA5505(config-if)# nameif backup-isp
ASA5505(config-if)# ip address Backup Isp 2 255.255.255.0
ASA5505(config)# route primary-isp 0.0.0.0 0.0.0.0 Primary ISP Exteral IP 1
ASA5505(config)# route backup-isp 0.0.0.0 0.0.0.0 Backup    (Isp )
Check also
nat (inside) 1 192.168.1.0 255.255.255.0
nat (inside) 1 0.0.0.0 0.0.0.0
route backup-isp 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx  2
global (backupisp) 1 interface
access-group 10 in interface backupisp
Finally I put this command
static (inside,backup-isp) yyy.yyy.yyy.yyy 192.168.12.49 netmask 255.255.255.255
Amardeep K
Nagaraja Thanthry Fri, 07/30/2010 - 09:34
  • Cisco Employee,
I see that there are no NAT rules for the primary interface in your
configuration. Let's try the following:
ASA5505(config-if)# no backup interface vlan 3
Amardeep Kumar Fri, 07/30/2010 - 10:03
Hi NJ,
I will try your Configration in off hours. But please explain it. last command. When there is not Vlan 3 in my config.
Here I want to know that what will be the reason I had to change all the static routes. and new records are running ,
Suppose I had below static before.
static (inside,outside) xxx.xxx.xxx.xxx 192.168.12.56 netmask 255.255.255.2     ( This was running before , I setup for Daul ISP)
static (inside,outside) xxx.xxx.xxx.xxx 192.168.12.77 netmask 255.255.255.2     (( This was running before , I setup for Daul ISP)
But I did not saving anthing on ASA and reboot it. After reboot both of uper static did not run. I tried xlate. But.....
Then I have to create new static and then I was able to access with new IP.
static (inside,outside) yyy.yyy.yyy.yyy 192.168.12.56 netmask 255.255.255.2
static (inside,outside) yyy.yyy.yyy.yyy 192.168.12.77 netmask 255.255.255.2
Please help
Amardeep Rana
Nagaraja Thanthry Fri, 07/30/2010 - 10:16
  • Cisco Employee,
The issue could be that the ISP router had wrong ARP entry for those IP
addresses. You might want to reboot your ISP router (or talk to them and
have them flush their ARP cache).
Hope this helps.
NT
Amardeep Kumar Thu, 08/05/2010 - 04:06
HI NT,
I have a Router 1841 that is given by ISP to terminate the link and they handle this router their self. I have rebooted that router. but after that I am again not able to access old IP series. I mean when I create a nat route from local to Live ip. this does not work. Please help ..
Amardeep Rana
