Query regarding outbound email headers
Answered Question
Jul 29th, 2010
Hi halijenn / experts
I am having ASA for which i have a seperate outbound mail access and the following is configured.The external interface of the firewall is 66.52.192.14.When i send the mail towards outside to @yahoo.com and then see the mail headers in the yahoo.com [i.e when i check the mail in yahoo and click on headers ), i see the Private IP Address of the organization mentioned / listed like "mxpb.akc.com (172.16.10.1)" in the "received from" field .Please let me know if this is normal ?Also , is it configurable on ASA so that it can be changed to the Public IP [ i.e MX Record ] or is it like that this behaviour totally depends on the YAHOO SMTP gateway ??
static (inside,outside) 66.52.192.15 172.16.10.1 netmask 255.255.255.255
where 172.16.10.1 is SMTP Gateway
Currently i dont have the "sh run" of the customer firewall , as soon as i get it i will post u the service-policy as well .However for the time being if u can throw the light on the same , it will be very helpful.
Correct Answer by Magnus Mortensen about 6 years 7 months ago
Ankur,
     I see in the headers that the private IP's make sense. You can see:
- MBX2 recieved it from MBX1
- MBX1 then gets it back from MBX2
- Exchange recieved it from MBX1
- Yahoo recieved it from your Exchange server
THe 172.x.x.x IPs are related to the internal communication between your servers (Exchange, MBX1 and MBX2) Yahoo does not see the internal IPs as expected. Yahoo sees it from your 67.x.x.x address. But up to this point, your internal email servers have already written the transaction logs in the email header using the IPs they saw (your internal 172.x.x.x ones). So all is normal from what I can see.
- Magnus
Overall Rating: 5 (1 ratings)
Nagaraja Thanthry Thu, 07/29/2010 - 06:17
That behavior seems to be normal. The firewall cannot change the SMTP packet contents. You could check on the mail server itself and see if there is a way to change the IP to a name (smtp.abc.com).
Hope this helps.
NT
Jennifer Halim Thu, 07/29/2010 - 07:09
The mail domain of "mxpb.akc.com" does not seem to resolve to anything. Are you sure that is the correct mail domain?
Here is the test that i did:
nslookup
> set type=mx
> mxpb.akc.com
*** UnKnown can't find mxpb.akc.com: Non-existent domain
Reverse lookup for the public ip address:
nslookup 66.52.192.15
Address:  66.52.192.15
And it's not something on the ASA that you can configure to change the behaviour.
Magnus Mortensen Thu, 07/29/2010 - 19:22
Ankur,
     What do the headers look like? If the recieveing host (the one just before/after) an internal IP as well? That line would be written into the email header by some SMTP relay who actually saw that connection come from IP 172.16.0.1. What are the lines above and below that line in the headers?
- Magnus
ankurs2008 Fri, 07/30/2010 - 03:54
hi halijenn / NT
thanks for looking into the same . the MX record sent across by me is a sample . Actually i was concerned for the email headers in the yahoomail as
iam not sure why private IP Address are visible over there .Please let me know if the mail server MX record is required for you to resolve the issue .
Hi Magnus
thanks for looking into this . Please find attached the snapshot of the yahoomail headers .I have blurred the IPs for confidentiality purpose .There are 2 email servers 172.X.X.1 [ MBX1.plprairiewi.com] and 172.X.X.2 [ MBX2.plprairiewi.com] which are visible in the headers .The Static command in the firewall is as follows (please ignore the static statement in my first mail as i have given dummy IP and MX Record earlier for confidentiality purpose].Please let me know if same is required for us to proceed forward.
static (inside,outside) 67.X.X.94 172.16.10.1 netmask 255.255.255.255
67.X.X.93 is the firewall IP [ exchange.plprairiewi.com ]
Also i am not able to understand as to why the field " X-Originating-IP" in the header is Firewall IP Address . Ideally it should be the 67.X.X.94
Correct Answer
Magnus Mortensen Fri, 07/30/2010 - 05:05
Ankur,
- Magnus
ankurs2008 Sat, 07/31/2010 - 01:39
Hi Magnus
thanks for the explanation , i just want to elaborate my understanding .please help me if i am correct
1)
The above sequence happens when the user sends the packet to exchange server and it seems to be that they pass the packet to each other as may be they are in NLB / Cluster .What i want to say is that MBX2  / MBX1 are exchange servers ( i believe that they are exchange (or domino) as customer has not told me about them and i am making my assumption)
Your above statement refers to exchange giving the packet to SMTP Gateway (and we can alsosee from the headers that though the name is exchange.plprairiewi.com , we can see that Microsoft SMTP Service is running on the same )
2) Also i want to understand is the reason for the Public ip of the firewall rather than the static IP appearing in the mail headers
Magnus Mortensen Sun, 08/01/2010 - 15:52
To address your concerns:  1) It looks like the first leg of the transaction is using IPv6 connectors. The the mail comes back on an IPv4 connector. This may be completely normal depending on your exchange config.  2) The external ip that the exchange will look like depends on the ip of the exchange server and any NATs or STATICs it might match. Whats is the internal IP?  - Magnus
ankurs2008 Mon, 08/02/2010 - 03:27
Thanks for the reply ! The IP 172.16.10.1 is the SMTP Gateway configured for Static as follows
Hence my query is that is it possible with the above config to see the Firewall IP Address in the "X-originating-IP" field instead of the one mentioned in tje static in the email header attached to this mail .
Magnus Mortensen Wed, 08/04/2010 - 04:23
Ankurs,      What ip address does your internal exchange server have? Since the exchange server is the last one of your servers in the header, it was the server that connected out to yahoo. If you do not have a STATIC for that host (1-to1 statuc, not static PAT) then he is most likely going to hit a PAT overload translation (ya know, a nat/global pair) when he establishes an outbound connection to the internet.   - Magnus
