ACS Wildcard Certificate Install for PEAP
Jul 29th, 2010
Does ACS support Wildcard certificate authentication, such as *.domain.com?  We installed the certificate through ACS using CA, but when using wireless devices, the certificate is still not verified.  Any information would be helpful before we go and purchase another certificate.  Thank you.
Overall Rating: 5 (1 ratings)
I'm running into this same issue, I think.  I found your question in my search, but see that no one ever replied.  Did you determine if a wildcard certificate will work with ACS and PEAP?  My test/trial tells me that it probably does not.  Any help or confirmation would be greatly appreciated.
Thanks.
Vinay Sharma Fri, 06/03/2011 - 04:27
  • Gold, 750 points or more
This issue is related to AAA. Moving it to AAA community.
Vinay
tbostrom Fri, 12/02/2011 - 18:39
  • Cisco Employee,
Can someone validate whether wildcard certs are supported with ACS and PEAP, please.  I'm running into the same issue that Jason outlines above.  It seems that Windows clients specifically don't like the wildcard cert. I have tried with Mac and iPhone and they seem to work if you accept the cert into the keychain on first connect.
wtribble80 Fri, 04/27/2012 - 10:57
I have this same exact question.  Wildcard Cert for ACS PEAP does not seem to work.
BUMP
wtribble80 Fri, 04/27/2012 - 12:30
Thanks Minakshi.  I will get a server specific cert.
minkumar Fri, 04/27/2012 - 11:16
  • Silver, 250 points or more
Unfortunately Wildcard certificates are not supported with ACS.
Minakshi (Do rate the helpful posts )
Related Content
