07-29-2010 06:45 AM - edited 03-15-2019 11:58 PM
Could you please recommend a Cisco router for below requirement.
There are 20 remote sites with same requirement.
1. Maximum of 4 users with IP Phones connecting to central site (Callmanager).
2. Bandwidth between remote and central site is 512 kbps (VSAT).
3. PSTN connection: 2-3 Analog lines (POTS).
4. Fax/Modem: One
5. SRST feature as fallback in case WAN link (VSAT) goes down.
6. Optional: 4 port PoE built in or module.
Mudassir
07-29-2010 05:29 PM
Cisco 880 and 890 are prime candidate. They have PoE daughter cards too.
07-30-2010 03:13 PM
I agree with the above post. +5 points!!
Please be sure when ordering that your order the SRST feature set.
Hope this helps, please rate if so.
Justin
