VLAN Mismatch
Jul 29th, 2010
Good luck with this one. We are getting a native VLAN mismatch and the native VLAN is the same on both 3750's:
We are getting the following logging on 3750-1:
Jul 29 01:12:43: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on
GigabitEthernet1/0/1 (620), with 3750-2 GigabitEthernet1/0/12 (1).
Jul 29 01:13:43: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on
GigabitEthernet1/0/1 (620), with Trent_Fibre GigabitEthernet1/0/12 (1).
Jul 29 01:14:43: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on
Jul 29 01:15:43: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on
Jul 29 01:16:43: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on
Here is the config for 3750-1:
VLAN Name                             Status    Ports
1    default                          active    Fa1/0/3, Fa1/0/4, Fa1/0/5
                                                Fa1/0/6, Fa1/0/8, Fa1/0/9
                                                Fa1/0/10, Fa1/0/11, Fa1/0/12
                                                Fa1/0/13, Fa1/0/14, Fa1/0/15
                                                Fa1/0/16, Fa1/0/17, Fa1/0/18
                                                Fa1/0/19, Fa1/0/20, Fa1/0/21
                                                Fa1/0/22, Fa1/0/23, Gi1/0/2
72   VLAN0072                         active    Fa1/0/1, Fa1/0/2
202  VLAN0202                         active    Fa1/0/24
620  Data                       active    Fa1/0/7
621  Voice                      active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
72   enet  100072     1500  -      -      -        -    -        0      0
202  enet  100202     1500  -      -      -        -    -        0      0
620  enet  100620     1500  -      -      -        -    -        0      0
621  enet  100621     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    -        0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
Remote SPAN VLANs
Primary Secondary Type              Ports
3750-1#
3750-1#
3750-1#
3750-1#sh int trunk
Port        Mode         Encapsulation  Status        Native vlan
Gi1/0/1     on           802.1q         trunking      1
Port        Vlans allowed on trunk
Gi1/0/1     1-4094
Port        Vlans allowed and active in management domain
Gi1/0/1     1,72,202,620-621
Port        Vlans in spanning tree forwarding state and not pruned
Here is the config on 3750-2:
1    default                          active    Gi1/0/5, Gi1/0/6, Gi1/0/7
                                                Gi1/0/8, Gi1/0/9, Gi1/0/10
                                                Gi1/0/11
620  Data                       active
621  Voice                      active
Remote SPAN VLANs
3750-2#
3750-2#
3750-2#sh int trunk
Gi1/0/1     auto         n-802.1q       trunking      1
Gi1/0/2     auto         n-802.1q       trunking      1
Gi1/0/3     on           802.1q         trunking      1
Gi1/0/4     on           802.1q         trunking      1
Gi1/0/12    on           802.1q         trunking      1
Gi1/0/1     1-4094
Gi1/0/2     1-4094
Gi1/0/3     1-4094
Gi1/0/4     1-4094
Gi1/0/12    1-4094
Gi1/0/1     1,620-621
Gi1/0/2     1,620-621
Gi1/0/3     1,620-621
Gi1/0/4     1,620-621
Gi1/0/12    1,620-621
Gi1/0/1     1,620-621
Gi1/0/2     1,620-621
Gi1/0/3     1,620-621
Gi1/0/4     1,620-621
Gi1/0/12    1,620-621
Please let me know what you think.
Nagaraja Thanthry Thu, 07/29/2010 - 06:55
  • Cisco Employee,
Can you please post the running configuration from both ports in question
here?
NT
Mark Bowyer Thu, 07/29/2010 - 07:19
interface GigabitEthernet1/0/1
description link to fibre switch
switchport mode trunk
end
interface GigabitEthernet1/0/12
end
Nagaraja Thanthry Thu, 07/29/2010 - 07:45
  • Cisco Employee,
Thanks for the outputs. Are you still getting those error messages or did
they stop? If you are not getting those error messages anymore, can you
check your logs to see if somebody made any changes to the configuration
during the period?
NT
Mark Bowyer Thu, 07/29/2010 - 07:57
Actually, dont worry. I double checked the time and date
again and it was when we made some configuration changes. Thanks for your help.
