Cannot Connect with AnyConnect on Mac
pristine711
AnyConnect installation was successful on the macbook I just purchased.
When I try to connect, I would get this message: “AnyConnect package unavailable on the Peer. Contact your system administrator.”
How could I solve this problem?
7 Replies 7
rahgovin
Level 4
Level 4
what version of the AC client are u using?
It's 2.2.0140.
Thanks for the quick reply.
I think you might be hitting a bug CSCsr52052 ....can u try with a newer client?
Yes, I tried 2.3 version. But that had the same issue. What version would work with Mac?
Thanks so much,
You could try the 2.4 version available for mac. the bug seems to be fixed in the 2.4 version.
Hi again,
I tried to install 2.4, and I get this message.
hey what version of OS X is this?
