How to configure Windows Vista PC using PLAP?
Answered Question
Jul 29th, 2010
We  are interested in cofigure our equipments to use VPN before To log on to Windows. No problema in XP but in  we need enabled something called PLAP to get appears the network login icon in the lower-right corner. The problem is how we can activiate PLAP. It seems this is a fetaure of VISTA itself but we are not able to find out where it is or how we do it.
Please, could you kindly send us some steps to solve this dubte?
Thank you very much in advance.
GEMMA NAVAS
JF HILLEBRAND SPAIN S.A.
[email protected]
Overall Rating: 5 (1 ratings)
g.navastrota Thu, 07/29/2010 - 08:17
Thank you for u quick reply!
The fact is I have been reading this document but
But I am not able to see this login icon!...whe the article says This displays a Vista Network Connect window (Figure 3-8) with the network login icon in the lower-right corner. The network login icon is circled in red
I need to install something before referred to PLAP or avtivate whatever in Windows VISTA to appear it but I do not know what.
Sorry about that.
g.navastrota Thu, 07/29/2010 - 08:57
Sorry but when I install AnyConnect Client I have not create any AnyConnect profile and nor the gina component has to be installed neither any profile (becuase I am not secure how to create i) has the following parameter  for SBL.
Please, could you kindly step by step what I can do form the beginning to the end of installation of AnyConnect Client 2.2.0???
Thank you very much for your kind assistace.
GEMMA
