dave.yeskey Mon, 08/08/2011 - 10:24
CSCsj45520 has been superseded by CSCtg93113.
Dear valued Cisco Bug Toolkit customer, the bug ID  CSCtg93113 you searched contains proprietary information that cannot be  disclosed at this time; therefore, we are unable to display the bug  details. Please note it is our policy to make all externally-facing bugs  available in Bug Toolkit to best assist our customers.  As a result,  the system administrators have been automatically alerted to the problem.
So now we can't even track the bug.
dave.yeskey Tue, 08/09/2011 - 07:26
Thanks.  Here's hoping it's because they are adding it to an upcoming release.
Rob Huffman Tue, 08/09/2011 - 08:38
Hi Dave,
Here's the response
Hi Rob,
CSCtg93113 has been marked by the engineering team as "internal" and hence it is not visible to customers and partners.
I have talked to the concerned engineers on displaying this bug in Bug Tool Kit. Meanwhile, this bug has been fixed and these are the fixed-in versions:
8.6(0.94130.14)
8.6(0.94130.46)
8.6(0.94130.51)
8.6(0.94130.78)
8.6(0.94130.91)
8.6(0.96000.56)
8.6(0.96000.143)
8.6(1.10000.43)
Deepika
Cheers!
Rob
Rob Huffman Fri, 08/12/2011 - 06:38
Hi Dave,
This bug is now visable and there is a fix
CSCtg93113            Bug Details
UCR2008 IA CLI, SSH, Web need a configurable timeout
Symptom:
This enhancement is required in UCM 8.6 to meet the DoD UCR2008 requirement 5.4.6.2.1.7-1.o.1 "The default for session inactivity is 15 minutes and shall be configurable"
We need to add an option for the system admin to configure what the inactivity timeout should be for the CLI/SSH and Web interfaces.
This will probably require a new CLI command (CLI/SSH timeout) and a new UCM service parameter (Web timeout).
We can leave our default timeouts of 30 minutes in place.
Conditions:
Communications Manager deployed in a highly secure network such as Department of Defense
Workaround:
None.  Upgrade to a version that includes this enhancement then use the following new CLI commands:
show cli session timeout
set cli session timeout < min>
show webapp session timeout
set webapp session timeout < min>
StatusStatus
Fixed
Severity Severity
6 - enhancement
Last Modified Last Modified
In Last 3 Days
Product Product
Cisco Unified Communications Manager (CallManager)
Technology Technology
1st Found-In 1st Found-in
8.6
Fixed-In Fixed-in
8.6(1.10000.43)
8.6(0.94130.91)
8.6(0.94130.46)
8.6(0.94130.51)
8.6(0.94130.78)
8.6(0.94130.5)
8.6(0.94130.14)
8.6(0.96000.143)
8.6(0.96000.56)
Related Bug Information
configurable CCMAdmin timeout
Symptom: Browser session to CCMAdmin times out after 30 minutes and user must re-authenticate.  Conditions: Browser session to CCMAdmin idle for 30 minutes with CM6.x.  Workaround: None.  Reauthenticate after 30 minutes of inactivity.  Further Problem Description: This is an enhancement request to allow configuration of web session timeout. Please contact Cisco account team or Cisco Product Manager for status, details, and updates about this enhancement request.
Cheers!
Rob
