CAT 3750 and ipsec
Answered Question
Jul 29th, 2010
hi,
Does the CAT 3750-24G-PS support encypto isakmp and ipsec? I was told by a reliable person that it does, but the IOS seems not. am I missing something?
thanks,
Correct Answer by Nagaraja Thanthry about 6 years 7 months ago
DSBU switches do not support IPSec tunnels. While sometimes the IOS might
accept the commands, it may not build the tunnels as expected.
Hope this helps.
NT
Correct Answer by August Ritchie about 6 years 7 months ago
That device does not support IPSEC or ISAKMP, the crypto support it does contain is for SSH.
However, if you have the WLC, it appears to have IPSEC support.
https://www.cisco.com/en/US/prod/collateral/wireless/ps6302/ps7185/ps6915/product_data_sheet0900aecd804b0879.html
Overall Rating: 5 (2 ratings)
Correct Answer
Nagaraja Thanthry Thu, 07/29/2010 - 08:54
Hope this helps.
NT
