Problem to record a Call From CUCM 7 with Verint Recorder
Answered Question
Jul 29th, 2010
Hi. I have two CUCM in my company, version 5 and version 7. I can normally record a call from CUCM5 and cannot from CUCM7. I used a Whire Shark to collect the packets and I confirmed that on CUCM5 I can see into the RTP packet the SKINNY protocol but I cannot see it on the RTP packet from CUCM7.
The IP phone models are 7911.
The firmware for 7911 in CUCM5 - 8.2.2
The firmware for 7911 in CUCM7 - 8.4.3
Correct Answer by Joseph Martini about 6 years 6 months ago
If Verint looks at the SCCP messaging to record calls they may not be compatable with SCCPv17 which was first introduced in CUCM 7.  Here's more information about the SCCP chagnes: http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/rel_notes/7_0_1/cucm-rel_notes-701.html#wp584451.
Overall Rating: 5 (1 ratings)
ALISSON CHAGAS Mon, 08/02/2010 - 16:46
Thanks for your answer. You got exact the point! I'm in contact with Verint and ask then for a upgrade.
bfriedopfer Tue, 03/26/2013 - 12:19
Hi, I'm having the same issue as stated above but can't open that link for some reason... Any chance you have another link or can highlight the info for me?
Rob Huffman Tue, 03/26/2013 - 13:37
Hi Brian,
Any time you see "partner" in the url just remove it and you should be
good to go
Here is the link;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_0_1/cucm-rel_notes-701.html#wp584451
Cisco Unified Communications Manager SCCP Messaging Guide
The following sections describe the changes to Cisco Unified Communications Manager SCCP Messaging Guide, Release 7.0(1):
SCCP Messages Added or Modified
SCCP Messages Deprecated
Release 7.0(1) adds or modifies the following SCCP messages:
StationAccessoryInfoMessage
StationButtonTemplateReqMessage
StationCallHistoryInfoMessage
StationMediaTransmissionFailureMessage
StationOpenMultiMediaReceiveChannelAck
StationOpenMultiMediaReceiveChannelMessage
StationOpenReceiveChannelAckMessage
StationOpenReceiveChannelMessage
StationRegisterMessage
StationRegisterTokenReq
StationServerResMessage
StationStartMediaTransmissionAckMessage
StationStartMediaTransmissionMessage
StationStartMultiMediaTransmissionAckMessage
StationStartMultiMediaTransmissionMessage
StationStartMulticastMediaReceptionMessage
StationStartMulticastMediaTransmissionMessage
StationStartToneMessage
StationStopToneMessage
StationUpdateCapabilitiesV3Message
Release 7.0(1) deprecates the following SCCP messages:
StationStartSessionTransmissionMessage
StationStopSessionTransmissionMessage
For More Information
Cheers!
Rob
"Hours are like diamonds, don't let them waste
Time waits for no one, no favors has he"
- Stones
bfriedopfer Tue, 03/26/2013 - 14:11
Rob,
Thanks!! I was able to get it working with JTAPI rather than ICM, but would still like to know why it's not working with ICM Tagging...
I'll read through the doc and see if there is anything that stands out.
