Searching object-group
Jul 29th, 2010
In ASA 8.0(4) the following command is not working?? Any Idea.
show object-group id GE-TP-UNITS
Apart from this can I know the tips and tricks to search object/object-group/ip/access-l in ASA and PIX...
August Ritchie Thu, 07/29/2010 - 09:20
I sometimes have troubles with object groups as well...
You can do "show run object-group id GE-TP-UNITS"
And for tips/tricks, I would just suggest if you can't find it with a specific command, just use the "show run | i" or "show run | be"
You can also do "show run access-list", "show run static", "show run nat", "show run global"
These are the common ones I use.
Hope this helps!
hstf_cisco Sat, 07/31/2010 - 08:45
you can add grep to search for specific object group name
sh run | grep object-group
