Wyse Terminal/PCoIP -> C871 -> IPsec tunnel -> ASA -> VM View Manager
Jul 29th, 2010
We are finding very poor performance with the path in the subject.  If we connect the IPsec tunnel to
a 3845 router instead of the ASA the performance was much better.  The ASA is a 5510 and we're
running 8.2 code.  Anyone have any experience with this?  Seen this scenario work fine?  Any
reason the ASA would gum up PCoIP performance over a connected L2L IPsec tunnel?
dmooregfb Fri, 08/12/2011 - 08:06
We are in the process of moving to the same environment. Did you have a resolution for this problem?
