Options for pre-recorded voice paging
Jul 29th, 2010
What options are there for pre-recorded voice paging on Cisco Phone Systems.
We are running Cisco Unity Express 3.1 on a Cisco 2851 and I have a ATA186 that connects to a PA System that has an extension assigned to it.
So what I would like to do is select between 2 or three pre-recorded messages and play it over that extension.
I know Informacast will do it but that is a little expensive in my opinion for what I want to do.
David Hailey Fri, 07/30/2010 - 14:24
In the same vane, check out Cistera as well.  You'll have to double-check the CME compatibility but they are generally cheaper (by quite a bit depending on deployment size) when compared to other popular choices.
upchaurasia Tue, 08/03/2010 - 09:19
Do you want to develop solution for paging? Cisco provides CUAE middleware API to develop voice , XML application for the CIsco IPT.
You can check that.
