Upgrading ASA 5510s failover pair to 5540s
Answered Question
Jul 29th, 2010
I am in the planning stage to upgrade ASA 5510s failover (active/standby) pair to 5540s.  Is it possible to load the config on the new 5540, replace the secondary 5510 with it, fail over to the 5540 and then replace the primary 5510 with the other 5540?
Thanks!
Correct Answer by mirober2 about 6 years 9 months ago
Unfortunately this is not possible. Failover requires that the hardware of both units is identical. As a result, the migration will require some downtime while you swap out the hardware.
Hope that helps.
-Mike
Overall Rating: 4.8 (3 ratings)
August Ritchie Thu, 07/29/2010 - 10:39
  • Bronze, 100 points or more
This is not possible as the ASAs require that you are running the same platform to maintain high availability.
Correct Answer
mirober2 Thu, 07/29/2010 - 10:39
  • Cisco Employee,
Hope that helps.
-Mike
smjaggers Thu, 07/29/2010 - 10:41
Thanks for the quick reply!  I was worried about that.
