Upgrade Callmanager 4.0
Answered Question
Overall Rating: 5 (3 ratings)
Correct Answer
Jaime Valencia Thu, 07/29/2010 - 11:17
  • Cisco Employee,
  • Hall of Fame,
    2011
Kinda, in many hops.
You need to go to 4.1(3) or 4.2(3) as the 1st hop.
Then to a 6.X or 7.X, and then finally to 8.X
Supported Cisco Unified Communications Manager Upgrades
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp43011
If you ask for a direct upgrade the answer is no.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Rob Huffman Thu, 07/29/2010 - 11:47
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey Java,
Hope all is well
+5 for this great help here! I've always been curious (so I thought I'd finally
ask an expert) why there are many references in the doc you linked and in
other docs on CCO to the fact that DMA migration to many 5.x and 6.x CUCM versions
shows support from CCM 4.0(2a)??
Here are two such examples;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp92373
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp57424
Cheers!
Rob
Jaime Valencia Thu, 07/29/2010 - 12:10
  • Cisco Employee,
  • Hall of Fame,
    2011
I'm not sure why 4.0(2) shows there, none of the Linux versions use that one as the foundation (later on I explain the importance of this).
5.X uses 4.1(3) as blueprint and 6.X uses 4.2(3).
Even if you look at the documentation for DMA, 4.0 is not mentioned, even when the upgrade matrix shows that it's possible.
Data Migration Assistant User Guide Release  6.0(1)
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/dma/6_0_1/dmaug601.html
DMA assists you with the first step in migrating  Cisco Unified Communications Manager data from versions 4.1(x) and  4.2(x) to Cisco Unified Communications Manager 6.0(1) by backing up this  data in a format that Cisco Unified Communications Manager 6.0(1) can  read.
You always need to be in the latest release of whatever train you're on. In the early days DMA lacked validation for this and you could get a DMA file from a 4.1(2) or a 4.2(1) CCM. Later this was enforced so you couldn't run DMA on any of those versions.
Usually the closest the versions are related to features is the upgrade path you can use.
ie 6.1(5)/7.1(5) are closer to 8.5(1) featurewise than previous 6.X or 7.X releases, so it's easier to upgrade.
But notice that they are the latest releases for their trains.
java
Rob Huffman Thu, 07/29/2010 - 12:47
  • Hall of Fame,
    Founding Member
Thanks Java!
+5 for taking the time to answer such a question.
Your explanation makes perfect sense and I've always followed these
same rules
Cheers!
Huff
