Multiple Access Points (1142N-A-K9) one SSID?
Jul 29th, 2010
Ok, another "quick" question   I currently have 1 access point and it's working fine however I'd like to add an additional access point, how  will I need to setup the radio's so that I only have one SSID?  I don't  know if I'm using the correct terminology here but the goal would be to  have one SSID for both access points so that it's seemless for someone  connecting to it if that makes sense.  Thanks!
Leo Laohoo Thu, 07/29/2010 - 16:21
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Copy the config from the current one, change the BVI1 IP address and copy it across.  Deploy the new AP so that the radios would cover one another so clients can cross one AP to another without loosing the link.
brenteverett Fri, 07/30/2010 - 06:24
Thanks for your reply!  I've got the additional AP setup currently however its the last part that I'm unsure of.  Right now the radio's on both AP's are configured as AP's, would I need to set one as the root or something similar so that a client can roam from AP to AP without losing connection?
Leo Laohoo Sun, 08/01/2010 - 15:52
  • Hall of Fame,
    2017 LAN, Wireless
Nope.
