Problems with simple dial-in ISDN
Jul 29th, 2010
im located in the few places in germany where there is no broadband connection. So I bought an old Cisco 803 ISDN Router.
I configured it like described in the manual. The local DHCP works and I can get a telnet connection.
However the router never tries to dial-in.
In the manual it says I need to create routes in and out of the ISPs Network through the router on the ISP side (175.148.1.1)
SanJose(config)# ip route 0.0.0.0 0.0.0.0 175.148.1.1
SanJOse(config)# ip route 175.148.1.1 255.255.255.255 dialer0
I don't have that Information. Is it really necessary or am I missing another point?
Thanks in advance.
Here is my Configuration:
Cisco803#show running-config
Building configuration...
Current configuration : 1536 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname "Cisco803"
boot system flash c800-y6-mw.122-13a.bin
no logging console
enable password 7 030E5A0F13
pots country US
ip subnet-zero
ip dhcp excluded-address 192.168.144.2 192.168.144.9
ip dhcp pool 1
   network 192.168.144.0 255.255.255.0
   default-router 192.168.144.1
   dns-server 192.168.144.1
no ip domain-lookup
isdn switch-type basic-1tr6
interface Ethernet0
description connected to EthernetLAN
ip address 192.168.144.1 255.255.255.0
ip nat inside
interface BRI0
no ip address
encapsulation ppp
dialer rotary-group 0
no cdp enable
ppp multilink
interface Dialer0
ip address negotiated
encapsulation ppp
dialer in-band
dialer idle-timeout 300
dialer string 08989058904
dialer hold-queue 10
dialer load-threshold 200 either
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname F0050236
ppp chap password 7 pass
ppp multilink
router rip
version 2
no auto-summary
ip nat inside source list 1 interface BRI0 overload
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 1 permit 0.0.0.0 255.255.255.0
dialer-list 1 protocol ip permit
no cdp run
snmp-server community public RO
snmp-server enable traps tty
line con 0
exec-timeout 0 0
password 7 1213041307
login
stopbits 1
line vty 0 4
password 7 pass
login
end
and here are the statuses of the interfaces:
BRI0 is up, line protocol is up (spoofing)
  Hardware is BRI with S/T interface and POTS
  MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
  Encapsulation PPP, loopback not set
  DTR is pulsed for 1 seconds on reset
  Last input 00:00:03, output 00:45:07, output hang never
  Last clearing of "show interface" counters 10:19:20
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/1/16 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 48 kilobits/sec
     8268 packets input, 33134 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     4878 packets output, 19552 bytes, 0 underruns
     0 output errors, 331 collisions, 0 interface resets
     1 carrier transitions
BRI0:1 is down, line protocol is down
  Keepalive set (10 sec)
  LCP Closed, multilink Closed
  Last input never, output never, output hang never
     Conversations  0/0/16 (active/max active/max total)
     0 packets input, 0 bytes, 0 no buffer
     0 packets output, 0 bytes, 0 underruns
     0 carrier transitions
BRI0:2 is down, line protocol is down
Dialer0 is up (spoofing), line protocol is up (spoofing)
  Hardware is Unknown
  Internet address will be negotiated using IPCP
  MTU 1500 bytes, BW 56 Kbit, DLY 20000 usec,
     Available Bandwidth 42 kilobits/sec
Ethernet0 is up, line protocol is up
  Hardware is PQUICC Ethernet, address is 00b0.c28b.eae8 (bia 00b0.c28b.eae8)
  Description: connected to EthernetLAN
  Internet address is 192.168.144.1/24
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 1/75/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 2000 bits/sec, 2 packets/sec
     19106 packets input, 1589938 bytes, 0 no buffer
     Received 17768 broadcasts, 0 runts, 0 giants, 0 throttles
     5318 packets output, 342486 bytes, 0 underruns
     0 output errors, 4 collisions, 2 interface resets
     0 lost carrier, 0 no carrier
