ASA 5505 and IOS
Jul 29th, 2010
I will be using an ASA on a customer site as a simple failover of an IOS based router mpls provider path. The ASA will have its own vpn tunnel path via a cable modem to the main HQ site for just one branch.
I wanted to automate the failover if the customer's branch router based wan circuit fails.
Does the ASA support HSRP/tracking or any other failover protocols between itself and another NON ASA device?
The docs do show support for failover and routing protocol options but no example with using an ASA and an IOS device as a single failover pair.
Any ideas are greatly appreciated.
Nagaraja Thanthry Thu, 07/29/2010 - 14:56
While ASA cannot participate in HSRP kind of scenario, you could do the
Step 1:
Configure the ASA as the default gateway for all the traffic
Step 2:
Connect the ASA and the router using a separate link
Step 3:
On the ASA, configure the router as default gateway with tracking option.
Step 4:
Configure a secondary route to same destinations through the ASA's outside
interface with lower metric.
This way, the ASA will send all traffic to the Router as long as the router
is active and if the router goes, down forward the same traffic via the VPN
tunnel. Alternatively, if you have another L3 device on the inside, you
could make that as the default gateway for your entire network and then do
route tracking on that.
Hope this helps.
