Limiting bandwidth on Cisco router (possible 1800 series)
Difan Zhao
Level 5
Level 5
Hi experts,
I'm just seeking some ideas in my setup scenario.
I will have this one router. Its f0/0 will be for the Internet connection with bandwidth of 30Mbps. Its f0/1 will be connected to a switch for internal networks. This link will be separated to 3 VLANs for 3 internal networks. I'm wondering if there is a way to gurantee 10Mbps for each VLAN but allow use up to 30Mbps when another two VLANs are not using any Internet bandwidth? I only worry about download bandwidth from internet.
The 3 internal networks will all have public IPs and they belong to their own subnets. There won't be NAT/PAT.
A sample config is greatly appreciated!
Thanks!
Difan
2 Accepted Solutions
gatlin007
Level 4
Level 4
The following example polices the inside interface to 30Mbps.  It also utilizes a fair queue mechanism so that all subnets are queued equally yet can use the entire purchased rate in the absence of competing traffic.
access-list 101 permit ip any a.a.a.a w.w.w.w ## Subnet A
access-list 102 permit ip any b.b.b.b w.w.w.w ## Subnet B
access-list 103 permit ip any c.c.c.c w.w.w.w ## Subnet C
class-map subnet-a
match access-group 101
class-map subnet-b
match access-group 102
class-map subnet-c
match access-group 103
policy-map subnets
class-map subnet-a
  bandwidth percent 33
class-map subnet-b
class-map subnet-c
exit
policy-map physical
class class-default
  police 30000000 conform-action transmit exceed-action drop
  service-policy subnets
exit
int fa0/1
service-policy output physical
exit
Dear christopher,
Thanks you for your post!!!!
So i would like to ask you some question that on your configuration you mean that Vlan A bandwidth 10MB,Vlan B bandwidth 10MB and Vlan C bandwidth 10MB right? if conrrect, so how can we know that the traffice can share 10 MB?
Best Regards,
Rechard
23 Replies 23
gatlin007
Level 4
Level 4
class-map subnet-a
class-map subnet-b
class-map subnet-c
policy-map subnets
class-map subnet-a
class-map subnet-b
class-map subnet-c
exit
policy-map physical
class class-default
exit
int fa0/1
exit
Dear christopher,
Best Regards,
Rechard
Rechard,
You are correct.
The parent policy (physical) limits the traffic to 30Mbps.  The child policy (subnets) allocates 33% of available bandwidth to each subnet.  In this case it should be very close to 10Mbps for each subnet.  This is a fair queue mechanism so it will only enforce the 10Mbps limit if all subnets are in contention with each other.  If subnet A and B are idle subnet C can take all 30Mbps.
Chris
Hi Chris,
Thank you very much for the config and the diagram!
However does it mean that I have to use secondard IPs instead of using VLAN sub-interfaces? I was going to create three sub-interfaces f0/1.10, f0/1.20 and f0/1.30. In this case I think I probably can still use your policy-map and class-map. However where do I implement the policy? If I put it under f0/1, will it affect all three sub-interfaces?
Thanks!
Difan
Difan,
Yes, applying it to the physical interface should affect all traffic traversing that interface; which includes all sub-interfaces.  This link has one example of this approach, but you must dig to find it.
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/Ethernet_Access_for_NG_MAN_WAN_V3.1_external.html
I'm not sure if this technique is supported on the 1800, but it's worth a try.
If not you could police each sub-interface.  This would ensure good service for everyone but leave bandwidth unused and unavailable during idle times.
Chris
Hi Chris,
It works great! I put it on f0/1 and it does affect all the sub-interfaces. Awesome solution! Thank you!
Difan
Disclaimer
The     Author of this posting offers the information contained within this     posting without consideration and with the reader's understanding  that    there's no implied or expressed suitability or fitness for any   purpose.   Information provided is for informational purposes only and   should not   be construed as rendering professional advice of any kind.   Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In     no event shall Author be liable for any damages whatsoever   (including,   without limitation, damages for loss of use, data or   profit) arising  out  of the use or inability to use the posting's   information even if  Author  has been advised of the possibility of  such  damage.
Posting
For the policy described, it might appear to be working correctly, but from what you've noted as your requirements, don't believe it does.
The issue I see is that parent is configured with a policer, not a shaper.  This indeed will limit overall bandwidth to 30 Mbps, but will not cause packets to queue in the child policy where each is guaranteed 1/3 of the bandwidth.
Other issues include: if the ingress link from Internet actually only provides 30 Mbps, how would there be excess bandwidth to manage on the egress link to the LAN?  If the ingress link actually provides more than 30 Mbps, an overall shaper or policer, applies to all traffic, i.e. it negates the excess bandwidth.  Additionally, downstream policers or shapers, although they can control bandwidth downstream of them, are not fully effective managing upsteam bandwidth.
The right way to apply this policy is to apply in at egress on the Internet side that's sending to you.  Unfortunately, often not possible because it's ISP equipment and they often will not cooperate.
Actulally i have  in my control the 2 routers that the fiber link is connected  and i want to slice the 50Mbit to 3 vlans
so if i apply this tou both routers then it will work for in and out for each router as as they would not be able to send mor than their limit resulting the other to receive at the same speed that it sends......
or am i wrong?
Disclaimer
Posting
No, you're not wrong.
If you control the two ends of the link, that's exactly want you want, a policy as described on both ends egress (to the fiber).
The parent policy's shaper restricts the overall bandwidth, since it's less than what the physical interface offers.  (NB: wouldn't be needed if you were using all the physical interface bandwidth, e.g. 100 Mbps fiber).
The child policy controls bandwidth sharing when there's congestion.
Just my 2 cents on this. You have a policer of 30Mbps on the interface between the router and the switch. This means that  any communcation between the subnets will also be restricted to 30mbps. not sute if u like that
What IOS does it need to work ?? because i have Entbase on my 2801 and it doesnt have the bandwidth command.
Deathshar
Hello, can i apply this to 3 different interfaces instead of subinterfaces?
I have 3 vlans on 3 different interfaces on a router and i want them to limit their bandwith throuth the out interface
the one vlan is for internet and the other 2 are private vlans.
Thanks for you time.
Hello everybody,
I have the same scenario, One internet (50mbps) and 3 vlans on the lan and I need shape each vlan (vlan1 25mbps, vlan2 15mbps and vlan3 10mbps) so I follow your instruccionts but if I connect to any vlan ever I have 50mbps then I make the test with 2 PC´s each in different vlan download and upload but the shape not work well.
If a show policy-map physical I can see that all traffic go to default class but I do not why?
Here is my config:
class-map match-any subnet-b
class-map match-any subnet-c
match vlan  3
match input-interface FastEthernet4
access-list 101 permit ip 10.1.1.0 0.0.0.255 any
access-list 102 permit ip 10.1.2.0 0.0.0.255 any
access-list 103 permit ip 10.1.3.0 0.0.0.255 any
policy-map subnets
class subnet-a
    bandwidth 25000
class subnet-b
    bandwidth 15000
class subnet-c
    bandwidth 9999
policy-map physical
class class-default
    shape average 50000000
interface FastEthernet0
ip address 172.16.1.10 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
end
interface Vlan1
ip address 10.1.1.1 255.255.255.0
ip nat inside
no autostate
end
interface Vlan2
ip address 10.1.2.1 255.255.255.0
ip nat inside
no autostate
end
interface Vlan3
ip address 10.1.3.1 255.255.255.0
ip nat inside
no autostate
end
Here the show policy-map....
Router1811#sh policy-map interface fa0
FastEthernet0
  Service-policy output: physical
    Class-map: class-default (match-any)
      5259740 packets, 7474775689 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: any
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 5259739/7474776995
      shape (average) cir 50000000, bc 1250000, be 1250000
      target shape rate 50000000
      Service-policy : subnets
        Class-map: subnet-a (match-any)
          0 packets, 0 bytes
          Match: access-group 101
            0 packets, 0 bytes
            5 minute rate 0 bps
          Queueing
          (pkts output/bytes output) 0/0
          bandwidth 25000 kbps
        Class-map: subnet-b (match-any)
          1137 packets, 95142 bytes
          Match: access-group 102
            1 packets, 66 bytes
            5 minute rate 0 bps
          Queueing
          (pkts output/bytes output) 1137/95142
          bandwidth 15000 kbps
        Class-map: subnet-c (match-any)
          0 packets, 0 bytes
          Match: vlan  3
            0 packets, 0 bytes
            5 minute rate 0 bps
          Match: input-interface FastEthernet4
            0 packets, 0 bytes
            5 minute rate 0 bps
          Queueing
          bandwidth 9999 kbps
          5258603 packets, 7474680547 bytes
          Match: any
          (pkts output/bytes output) 5258602/7474681853
