UCS C200/C210 - Slow Mouse & keyboard on Win2K8 R2
Jul 29th, 2010
  • Cisco Employee,
DRIVER UPDATE ADVISORY
Symptoms:
Slow system performance including slow or "laggy" keyboard, mouse and video.
Affected Systems:
Windows Server 2008 R2
Cause:
There is a know issue with the Intel 82576 driver included with Windows Server 2008 R2.  This issue is not vendor/platform specific. /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Resolution:
Download and install the latest Interl 82576 driver from Inter's support website: /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Ethernet+Components&ProductLine=Ethernet+Controllers&ProductProduct=Intel%C2%AE+82576+Gigabit+Ethernet+Controller&ProdId=3024&LineId=976&FamilyId=2280
jogentry Sat, 10/15/2011 - 13:17
  • Cisco Employee,
Is there a way to include these drivers in the installation of Windows instead of trying to install them after? It seems the latest drivers from Intel come in a self-extracting EXE.
Robert Burns Sat, 10/15/2011 - 15:47
  • Cisco Employee,
Yes -  you can slipstream any after market drivers into the install .iso.
There's tonnes of online guides detailing how to do this.
Robert
