Rommon reload IOS but tftp timeout
Jul 29th, 2010
hi,
i try load the new IOS C1841-ADVENTERPRISEK9-MZ.124-24.T3.bin to C1841 ISR. Everything seems fine about the setting on the rommon, but once it y copy to almost 70% my TFTP prompt operation aborted: timeout.
i check the log of my TFTP applicatin, showing "dropped because peer didn't respond", during the copy process i doing ping -t test, once it timeout , the router interface also showing timeout.
my topology is direct connection, using a crossover cable. default gateway is using router interface IP.
anyone can help? would it be anything deal wit the IOS i download?
thank you
Noel
Leo Laohoo Thu, 07/29/2010 - 23:08
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Are you using TFTP32 as a client?
yong khang NG Thu, 07/29/2010 - 23:28
Anyway, anyone know what's the meaning of "ACK block 0 ignore" mean?
then it hold and timeout occur
thank you
Leo Laohoo Sun, 08/01/2010 - 15:51
  • Hall of Fame,
    2017 LAN, Wireless
Try uisng TFTP32.
Nagaraja Thanthry Mon, 08/02/2010 - 12:19
  • Cisco Employee,
Most of the older TFTP servers do not support file size greater than 16 MB. TFTPd32 is one of the TFTP server implementations that supports file size greater than 16 MB. You can download TFTPd32 here:
http://tftpd32.jounin.net/
The symptoms you are explaining seems more like the issue with the TFTP server not supporting bigger images. So, please try using TFTPd32 and see  if that helps.
NT
