07-25-2010 01:34 AM
If WPA-PSK TKIP or AES encryption is enabled, my Spectec SDW-821 SDIO wlan card can not connect to the WAP4410N (h/w "WAP4410N-E V02", f/w 2.0.2.1). If security is off or set to WEP 128 bits (thanks to Cisco's support), connection succeeds
The card worked well with my previous AP Netgear ME-102 (in WEP 128 bits mode) and DLink DWL-G700AP (in WPA PSK TKIP mode).
The AP is not faulty since the other laptops connect successfully, only my pocket PC with the SDIO card fails
Thanks for help
07-27-2010 10:16 AM
Here are the logs (Spectec card MAC addr replaced with xx:xx:xx:xx:xx:xx). Someone from Cisco here to help me ?
Is it possible to have more detailed log to better see the problem?
Jul 27 18:47:24 kernel: [][xx:xx:xx:xx:xx:xx] SUBTYPE_AUTH
Jul 27 18:47:24 kernel: [MySSID][xx:xx:xx:xx:xx:xx] Associated
Jul 27 18:47:26 kernel: [][xx:xx:xx:xx:xx:xx] SUBTYPE_AUTH
Jul 27 18:47:26 kernel: [MySSID][xx:xx:xx:xx:xx:xx] Associated
Jul 27 18:47:27 kernel: [][xx:xx:xx:xx:xx:xx] SUBTYPE_AUTH
Jul 27 18:47:27 kernel: [MySSID][xx:xx:xx:xx:xx:xx] Associated
Jul 27 18:47:29 kernel: [][xx:xx:xx:xx:xx:xx] SUBTYPE_AUTH
Jul 27 18:47:29 kernel: [MySSID][xx:xx:xx:xx:xx:xx] Deauthenticated
Jul 27 18:47:33 kernel: [][xx:xx:xx:xx:xx:xx] SUBTYPE_AUTH
Jul 27 18:47:33 kernel: [MySSID][xx:xx:xx:xx:xx:xx] Associated
Jul 27 18:47:34 kernel: [][xx:xx:xx:xx:xx:xx] SUBTYPE_AUTH
Jul 27 18:47:34 kernel: [MySSID][xx:xx:xx:xx:xx:xx] Associated
Jul 27 18:47:36 kernel: [][xx:xx:xx:xx:xx:xx] SUBTYPE_AUTH
Jul 27 18:47:36 kernel: [MySSID][xx:xx:xx:xx:xx:xx] Deauthenticated
Jul 27 18:47:40 kernel: [][xx:xx:xx:xx:xx:xx] SUBTYPE_AUTH
Jul 27 18:47:40 kernel: [MySSID][xx:xx:xx:xx:xx:xx] Associated
Jul 27 18:47:41 kernel: [][xx:xx:xx:xx:xx:xx] SUBTYPE_AUTH
Jul 27 18:47:41 kernel: [MySSID][xx:xx:xx:xx:xx:xx] Associated
Jul 27 18:47:43 kernel: [][xx:xx:xx:xx:xx:xx] SUBTYPE_AUTH
Jul 27 18:47:43 kernel: [MySSID][xx:xx:xx:xx:xx:xx] Deauthenticated
Jul 27 18:47:45 kernel: [][xx:xx:xx:xx:xx:xx] SUBTYPE_AUTH
Jul 27 18:47:45 kernel: [MySSID][xx:xx:xx:xx:xx:xx] Deauthenticated
Jul 27 18:47:46 kernel: [][xx:xx:xx:xx:xx:xx] SUBTYPE_AUTH
Jul 27 18:47:46 kernel: [MySSID][xx:xx:xx:xx:xx:xx] Deauthenticated
Jul 27 18:47:46 kernel: [MySSID][xx:xx:xx:xx:xx:xx] Associated
Jul 27 18:47:48 kernel: [][xx:xx:xx:xx:xx:xx] SUBTYPE_AUTH
Jul 27 18:47:48 kernel: [MySSID][xx:xx:xx:xx:xx:xx] Associated
Jul 27 18:47:49 kernel: [][xx:xx:xx:xx:xx:xx] SUBTYPE_AUTH
Jul 27 18:47:49 kernel: [MySSID][xx:xx:xx:xx:xx:xx] Deauthenticated
08-09-2010 01:27 AM
I discovered that when the Pocket PC is trying to connect to the AP, it was detected as being connected in the "Wireless Client List" window ("Wireless->Connection Control" menu, then "Wireless Client List" button) - see attached image - but in fact the connection was not established.
So I suspected a DHCP problem and I configured a static IP on the Pocket PC, then on the router, but without success.
09-08-2010 12:48 PM
The problem still occurs with 2.0.3.3 firmware (WPA PSK TKIP does not work)
07-13-2011 01:33 AM
Not solved with 2.0.4.2 firmware
