Cisco Pix 506 global outgoing address
Jul 30th, 2010
I currently have a Pix 506 in place with a block of 5 ip addresses and so I'm able to have an outside interface address and an outgoing global ip address for NAT.
My question is, I'm moving to Brazil and the ISP there is only going to give me 1 static ip address, is there a way to set the pix up so that it doesn't need the global ip address or that the outgoing ip address is the actual outside interface ip address???    Everywhere I've set these things up have always had a block of ip's and so it was never an issue, but now that I'm getting only 1 ip address I need some help in figuring out if it's possible to use my 506 or if I'm going to have to settle for a cheap wireless ap/cable router.
Thanks.
Rob
casbot Fri, 07/30/2010 - 00:57
Perfect!!! Thanks.  I just changed it here now and all my other statics are working fine still.
I appreciate your help.
Rob
Related Content
