vpnv4, ipv4 and next-hop-self
Jul 30th, 2010
In a back-to-back VPN connection (prefixes are transferred as ipv4 prefixes in an eBGP session) we observe that the ASBR imports prefixes into vpnv4 with next-hop-self. For ipv4 next-hop-self is not automatically set. Is there any explanation, documentation or even standard for this different treatment of the prefixes?
Thanks for any hint.
Giuseppe Larosa Fri, 07/30/2010 - 08:24
Hello Matthias,
in address family vpnv4 the next-hop is changed automatically, because it needs to be an address in the global routing table and so the eBGP next-hop learned in the eBGP session in VRF cannot be reused.
This is needed in order to have a working forwarding plane
This does not happen in af ipv4 because the original eBGP next-hop can be retained being part of global routing table on ASBR/PE node, in this case setting next-hop self may solve problems of installation of BGP routes in downstream iBGP peers as they could not know how to reach theoriginal  BGP next-hop.
Hope to help
