Log message is not logged in buffer
Answered Question
Jul 30th, 2010
Hello
my name is yun choulj jung in korea
Yesterday, i changed a logging buffer size in Catalyst 4510R-E and up and down the fastethernet interface.
but interface up/down status is not logged in buffer memory.
so, i rechanged a configuration originally and reboot the chassis.
but log was not saved in buffer.
i know the bug id CSCdu60369.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCdu60369
So, i "no logging syncrous" command enterd but result was same.
Environment
C4510R-E (cat4500-entservicesk9-mz.122-31.SGA11.bin)
H_NEW4510R_A#show logg
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
    Console logging: level debugging, 329 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 6 messages logged, xml disabled,
                     filtering disabled
    Buffer logging: level debugging, 89 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (8192 bytes)
    Count and timestamp logging messages: disabled
    Trap logging: level informational, 333 message lines logged
Log Buffer (4096 bytes):
i attached the configuration
tell me the workaround or advice.
thanks in advance.
by yunchouljung
Correct Answer by Brandon Lynch about 6 years 7 months ago
Hey Yun Choulj Jung,
Can you try configuring the following globally on the switch -
logging event link-status
If that doesn't take, try going into the interface configuration and configuring it.  Then, bounce the interface and let me know what you find.  Thanks.
Brandon
Overall Rating: 5 (1 ratings)
Correct Answer
Brandon Lynch Wed, 08/04/2010 - 06:16
  • Cisco Employee,
Brandon
yunchouljung Thu, 08/05/2010 - 06:39
thank you, brandon
the problem is resolved because of you
again, thank you very much!
Related Content
