how to find out how many space character in setence (string var) ?
Answered Question
Jul 30th, 2010
Dear all Master,
I need Your help please.
Topic:
Script Editor.
My System:
-CUCM 7.0
-UCCX 7.0 premium
-Nuance recognizer 9.0
Question:
ABC = string var.
ABC = "this is sample"
2 space character in ABC string var.
How to find out how many space character in ABC var ?
Susanto
Correct Answer by Aaron Harrison about 6 years 5 months ago
Create a int variable called whatever you want, then insert a SET step.
Set the variable to the new int you created, and then paste this into the 'value' field:
String[] myarray = teststring.split(" ");
return myarray.length -1 ;
Basically it splits the string into chunks each time it hits the " " character.
This results in an array of the resulting chunks (i.e. words), which is one more than the number of spaces. -1 from that, and you have your int variable set to the number of spaces.
Aaron
Please rate helpful posts...
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Fri, 07/30/2010 - 02:51
Aaron
Related Content
