6509 not viewable in CiscoView
Answered Question
I am currently running CiscoWorks LMS 2.6 which contains CiscoView 6.1.5. (Build Id :NT_CVW6_1_5_INCR_UPDATE_20060901_0601)
CiscoView works fine for all my nodes apart from my 6509s. When I try to access them i get the following error message:
Message
Can't find applicable device package for <ip address>.
Cause
Device package for this device type is not installed or device support for this device type might not be available or you are attempting to open a component inside a device.
Action
Please install a device package for the device type or open the parent device to manage the component.
I have updated the available device packages, and any software updates available. Can anyone help?
Correct Answer by Joe Clarke about 6 years 7 months ago
You're missing the CVGenericPackage.  You should have a CVGenericPackage.zip file in both of the previously mentioned directories.  You should be able to find this package on Cisco.com or from Common Services > Software Center > Device Update.
Overall Rating: 5 (1 ratings)
Joe Clarke Fri, 07/30/2010 - 11:22
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What version of the Cat6000IOS package do you have installed?  What is the sysObjectID of this 6500?
Joe Clarke Mon, 08/02/2010 - 10:36
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It sounds like you may have some map file corruption.  Post the cvw map files under NMSROOT/www/classpath/com/cisco/nm/xms/psu/maps.
Joe Clarke Tue, 08/03/2010 - 08:50
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
These files are corrupt.  This was most likely triggered by CSCsj58812.  While the bug is fixed in Common Services 3.0.6, once the map files are corrupt, they need to be recovered.  The bug workaround lists the steps to do this.
Once the maps are recovered, you should be able to upgrade your installed Cat6000IOS package to 30.2 (along with the related packages).  That should allow you to view your 6500.
I have tried the workaround in bug CSCsj58812, unfortunately I get the following error when I run the commands:
log4j:ERROR No appenders could be found for category (com.cisco.nm.xms.psu.util.PackageUtils).
log4j:ERROR Please initialize the log4j system properly.
I have tried this with the CW Deamons running and stopped. I still get the java.util.NoSuchElementExceptionerror when I try to access the device packages.
Joe Clarke Wed, 08/04/2010 - 09:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This error is normal.  Make sure you delete the two cvw map files before running the command.  If, after doing that, you still get the error in the UI, post all of the map files.
First of all many thanks for your help so far
The commands have recovered the map files, and I can now see the package information, but the fault still occurs.
I am using the following packages:
Cat6000IOS30.2Cat6000IOS Device Package
I have even deleted this package and downloaded it again, but I still get the error on all four of my 6509s
I have attached the latest map files.
Joe Clarke Thu, 08/05/2010 - 19:53
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Post the list of contents in NMSROOT/MDC/tomcat/webapps/CVng/WEB-INF/classes/com/cisco/nm/cvw/devpkgs and NMSROOT/www/classpath/com/cisco/nm/xms/psu/pkgs/cvw.
Joe Clarke Sat, 08/07/2010 - 10:40
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
To be clear, you are still seeing the error about not finding an applicable package for the device?  If so, post the cv.log.
Steveheggie Mon, 08/09/2010 - 01:34
Unfortunately the error still occurs whenever I select a 6509. All my other switches are fine:
Message
Can't find applicable device package for p_address>
Cause
Action
I have attached the cv.log
Joe Clarke Mon, 08/09/2010 - 21:28
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Post the output of "cacls *" from the devpkgs directory as well as the NMSROOT/MDC/tomcat/logs/stdout.log and stderr.log.
Correct Answer
Joe Clarke Fri, 08/13/2010 - 23:09
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Related Content
