Ciscoworks 3.0 rechability check fails.
Jul 30th, 2010
Hi friends,
The reachability check fails while checking in Ciscoworks but there is no reachability issue as such. The credentials are also fine. But still the devices are not being imported to DFM / RME.
Screenshots attached.
Rajiv
Overall Rating: 4 (1 ratings)
Joe Clarke Fri, 07/30/2010 - 11:24
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The biggest problem here is the lack of SNMP connectivity.  Verify that your SNMP credentials in DCR are correct.  If they are, check the device to make sure the LMS server is allowed to poll it with SNMP.
Rajiv Dasmohapatra Wed, 08/04/2010 - 11:01
The devices have snmp-server host configured too. But then too there are issues. I also noticed that while deleting some of the learning devices in DFM rediscovery/delete, the devices got stuck as pending devices and were not getting deleted even after hours.
May be reinstallation of the DFM will resolve the issue. Could you please suggest any things that i need to check?
Best Regards // Rajiv
Joe Clarke Wed, 08/04/2010 - 12:22
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Exactly what version of DFM do you have?
