IME showing no events
Jul 30th, 2010
I was wondering if someone could help with an issue I am experiencing at the moment with IME events.
I have two sensors (AIP-SSM-10's) installed with the lastest engine and signature versions, linking back to IME.  If I connect using IDM I can see plenty of events however if i look at either historic or real time events via IME there is no data.  The sensors have been added succesfully and I can go through configuration etc but just no events.
I am running IME Version 7.0.3
Any help would be much appreciated.
Siddharth Chand... Fri, 07/30/2010 - 11:48
Few things to check:
1. Check if you are seeing events on IPS via CLI or IDM first.
To access IPS via IDM:
If yes, then there is no issue with IPS itself and the issue is IME related.
2. When you added the IPS device to IME, in 7.0.3, make sure you enter correct username and password for 'Event subscription'.
By default its the same username and password that is used for authentication.
3. start>run > services.msc
Restart:   Cisco IPS manager express
Now see if you start seeing events again.
- Sid
