Error in ASA 5510
Jul 30th, 2010
Hi all,
while configuring the ASA 5510 for VPN I encountered this error
This showed after I enter this command
ciscoasa(config-pmap-c)# inspect dns migrated_dns_map_1
ERROR: DNS policy-map migrated_dns_map_1 not configured
What is the meaning of this error and how will i troubleshoot this?
Rahul Govindan Fri, 07/30/2010 - 04:39
do you have a policy map by the name migrated_dns_map_1? you can probably check by doing a show run policy-map.
If not you can try creating a policy map for dns by configuring:
policy-map type inspect dns migrated_dns_map_1
parameters
  message-length maximum client auto
  message-length maximum 512
what version of the ASA are you running?
Jitendriya Athavale Fri, 07/30/2010 - 04:54
this is what you would have by default
policy-map type inspect dns preset_dns_map
parameters
if you have this just call this L7 policy map in your global policy
