Call Manager Cluster Upgrade Procedure
Jul 30th, 2010
Hi Guys,
Just a couple of questions about a CUCM Cluster Upgrade.
So I've got a 2 server cluster.  If I move all my devices off the PUB and onto the SUB, I upgrade the PUB first.
Once the PUB is upgraded, how do I get the devices to re-register from the SUB to the PUB if I wanted to simply test the PUB.  Because if I go onto the SUB after the PUB has been upgraded, I can't make any changes, so I can't change the server order of the device pool.
or is it a simple case of not being able to fully test until both have been upgraded?
I'd appreciate some advice,
Neil
Overall Rating: 5 (1 ratings)
Jonathan Schulenberg Fri, 07/30/2010 - 05:10
  • Cisco Designated VIP,
    2017 IP Telephony
Unplug the subscriber from the network; the phones will fallback to the secondary UCM node in their CM Group automatically.
neilobrien Fri, 07/30/2010 - 05:15
thanks Jonathan, simple but effective.!!
**EDIT**  Actually - the reason I shy'd away from that was because I was hoping to be able to test a small device pool without everything moving over.
