Connecting two local networks
Jul 30th, 2010
We have two offices a couple of miles apart connected via a 10MB Ethernet link provided by Virgin Media Business for the purposes of business continuity replication. Office A is on a 192.168.10.0/24 network and Office B is on a 192.168.17.0/24 network. I want to connect the two networks, but cannot change their IP addresses or subnet mask as there is a MPLS cloud in place already for standard network traffic.
We have a Cisco RVS4000 router lying about, however I don’t seem to be able to get the routing working between the two networks. Is this possible with this device, or should I be looking at something like an 800 series router?
Many thank.
Nagaraja Thanthry Fri, 07/30/2010 - 07:04
I do not think RVS400 would be a best fit in your environment. You will need a router that can route traffic between two subnets. If you are not worried about full connectivity between the two subnets, then you can buy a simpler Linksys Home Router and put it between the subnets. But if you are looking for full connectivity, then I would suggest at least a 800 series router.
Hope this helps.
NT
