07-30-2010 05:51 AM - edited 03-19-2019 01:20 AM
Hi all,
Can someone tell me if Unity Connection's Visual Voicemail (VVMO) is supported through Citrix environments ?
I did not find any information about it except from many discussions on the Cisco Support Community forum where people where asking for compatibility between Viewmail and Citrix clients:
https://supportforums.cisco.com/message/342482#342482
https://supportforums.cisco.com/message/389383#389383
https://supportforums.cisco.com/message/302487#302487
In all these threads, the answer is the same: VMO is not supported with thin clients.
Is the answer the same for VVMO ? If it is doable, is there any restriction ?
Thanks in advance,
Julien
08-05-2010 02:11 AM
Really no idea ?
Thanks again,
Julien
08-05-2010 05:32 AM
Visual Voicemail is an XML based phone app : http://www.cisco.com/en/US/docs/voice_ip_comm/cupa/visual_voicemail/7.0/english/install/guide/plan.html
It runs on your phones display, not on a Citrix or desktop PC session.
The only scenario I see with it running in Citrix is if you are running CIPC in Citrix; is this what you are trying to do?
Aaron
08-06-2010 08:19 AM
Hi Aaron,
My apologies, you are totally right... my question is not relevant
In fact my client was asking for viewmail compatibility, so I already have my answer !
Thanks for your help !
Julien
