CUCM 7.1 SIP Trunk to Asterisk DNIS Problem
Jul 30th, 2010
I am trying to utilize a SIP trunk to stream voice traffic to an asterisk Contact Center solution using a dial plan, the problem that I am running into is I am able to see the ANI or the DNIS by messing with the "Calling Party Selection" in the "Outbound Calls" section of the Trunk configuration but not both at the sametime. Is there something that I am missing? Any input is greatly apprectiated.
Adam Frankel Sun, 08/01/2010 - 22:06
  • Silver, 250 points or more
You should be able to modify both.
Can you give an example of how changing one does not allow you to change the other?
Also, what is your exact version of CUCM?
Adam
