Router888 as firewall and OWA exchange 2007
Jul 30th, 2010
Hi to all,
I have a router 888 used to access to SHDLS and as firewall, I try to publish a Exchange 2007 OWA, I do the NAT for port 443 and open the port on firewall, but when I try to connect to the url (https://IPaddress/owa) I obtain a generic error "404 not found", inside the router on the LAN OWA works fine, I think is it a problem on firewall inspection, any body know the problem and the solution?
Thank you very much
ahmad82pkn Fri, 07/30/2010 - 07:38
From internet do telnet publicip-OWA 443  , or use some onlnie port scanner site to do this for you.
you should get simillar screen as you get when you do this on internal ip. if not then you NAT/Firewall rules are incorrect
m.ronchetti Mon, 08/02/2010 - 00:07
The port 443 is open (I try also open 80), I think the problem occur when exchange redirect the url to its web application.
