T3 muxing
Answered Question
Jul 30th, 2010
We have t3 coming into our facility feeding a mux which breaks out this circuit into individual t1s which we feed to our internal router.  I would like to bring this muxing component internally into the router and breakout the t1s logically with separate IPs internally.   I have a nm-t3/e3 board from a previous project that I would like to re-use.  Is this even possible and can someone point me to a document?
Correct Answer by Giuseppe Larosa about 6 years 9 months ago
Hello Jgadbois,
you need a channelized network module for doing this and you would need to move all the T1 links to the router with the channelized module you cannot use the module as an ADM
The module you have is not the correct one it is not channelized.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Fri, 07/30/2010 - 08:10
  • Hall of Fame,
    Founding Member
Hello Jgadbois,
Hope to help
Giuseppe
jgadbois Fri, 07/30/2010 - 08:28
G,
Had to look up ADM but now I know.  Thanks for your reply.  I think I rated the response correctly.
J
