07-30-2010 08:31 AM - edited 03-04-2019 09:15 AM
Consider i have multiple LSP paths in an mpls cloud.
How to know the amount of traffic flow / byte switched on per LSP.
Which command is used to view?
Pramod
08-04-2010 10:18 PM
Hi Pramod,
How the LSP's are built? Is it with LDP, then by default LSP will be built from IP routing table. In this case, its difficult to get traffic flowing a particular LSP because number of LSP's are proportional to the number of routers enabled with MPLS/LDP.
If LSP is built with MPLS TE tunnels, then traffic count can be taken from TE tunnel counters.
HTH...
Arun
08-04-2010 11:30 PM
yes, u r right LSP's are formed using IGP's table.No TE tunnels. I can see only the bytes switched on P devices.
but not source to destination level, at this level
Hope we have to wait till cisco comes with a new solution !!! :-)
