Service-policy output LLQ not supported !!
Answered Question
Jul 30th, 2010
I am trying to configure service-policy output LLQ on WS-X6724-SFP module and getting error message as below:
(config)#int gi 8/1
(config-if)#service-policy output LLQ
priority command is not supported in output direction for this interface
Configuration failed!
Device model information:
cisco 7609 with sup 720 and pfc3
Can any one say why the error message happens, and what is the remedy for this ?
Or the same configuration is not supported for this interface ?
Please help...
Correct Answer by Giuseppe Larosa about 6 years 11 months ago
Hello Richard,
the port belongs to a linecard that does not support the modular QoS setup but only the QoS WRR of LAN switch ports.
Only ports of SIP linecards or ES 20/40 linecards or ports or "WAN" modules like older OSM supports modular QoS like in a software based router.
The warning tells you this fact.
There is nothing wrong with your configuration, unfortunately it cannot be applied to this hardware.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Jayakrishna Mada Fri, 07/30/2010 - 09:58
  • Cisco Employee,
Please take a look at the following QoS guide:
not sure if you are using any of these keywords mentioned in the guide under the policy-map which are not supported:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/qos.html#wp1581673
what is your goal ? can you post the class-map and policy-map here.
JayaKrishna
Correct Answer
Giuseppe Larosa Fri, 07/30/2010 - 12:11
  • Hall of Fame,
    Founding Member
Hello Richard,
Hope to help
Giuseppe
Richard.Jeff Sat, 07/31/2010 - 03:36
Could you please let me know if there is a better way other than configuring LLQ to prioratise my traffic...
